    Results 1 to 2 of 2
      May 2007
      Midwest City, Ok
      Power Valve Size
      I bought a motor about a month ago and the guy suggested getting the carb rebuilt. So I got the carb back about a week ago and the shop rebuilt it back to stock specs. I was wondering if with my motor specs I could get an idea of the correct or close to correct power valve size? The motor is not in the car right now and on an engine stand, but I would like to get the carb close to ready as possible.
      502 Gen VI 4 bolt main, 9:1 CR
      Melling hv oil pump
      Crane solid roller p/n 168601 cam .615 .636 246 254 dur @ .050,
      crane solid roller lifters
      GMPP 12363400 Aluminum Rectangle port heads
      GMPP 12361323 1.7 alum Rockers
      Edelbrock victor jr 454-R intake
      Crank Ext. ballanced, nitriated, crossed drilled gm p/n 10198922
      Rods Forged 4340 Steel
      Pistons GM P/N 12533507 Forged Aluminum
      MSD Pro-Billet Dist.
      Per holley's website, if I remember right, you need to check the motor vacuum first. At op temp, if auto, in gear, and check the idle vacuum, then use a PV that is half of that reading.
      Like 10" of vacuum, use a 5 power valve. Seems to have worked pretty well for me.
      94 S-10 / V8 / 6 speed / 8.5 rear / ATS spindles / QA1 coilovers / 14"C6Z brakes
