    Results 1 to 10 of 10
      Wichita, KS
      Engine Hole?? - Back of Block - Mark VI
      Does anyone know what this hole is for? I am assuming I just block it off - correct ??
      Apr 2008
      Country Flag: Sweden
      I'm pretty sure it's for the oil pressure contact.
      Apr 2008
      socal
      oil pressure
      Dec 2007
      New York
      Ditto on the oil pressure port.
      Henderson,NV
      Man plug that hole! That is your oil galley. Anyway...I just put on my sensor for my autometer oil pressure gauge a few nights ago. You will need a 1/4 inch pipe plug with 1/8 female threads for the block....a 1/8 male/female elbow connector.....and finally the sensor to make it work there. The sensor will hit the block when you tighten it down if you don't use the elbow.
      Todd
      Wichita, KS
      I have my oil pressure going into the port right above the oil filter. I am sure both places are acceptable places to get a pressure reading from - correct?
      Hell that hole back there would be hard as hell to get to once the motor is in.
      Brian
      Henderson,NV
      That will work fine...I am running my plug wires underneath so that would be right in my way. I used plenty of sealer so I hope to have no leaks.
      Todd
      Wichita, KS
      Quote Originally Posted by Vegas69
      Yeh hope you don't either. I checked out the thread on your ride... 2 words explain what I think about it... Goooooooooooooot Daaaaaamn!
      May 2002
      Northern California
      one question big boi...can you see through the hole?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Wichita, KS
      Quote Originally Posted by MrQuick
      Yes. It goes down into the oil galley.
      I plugged it with a 3/8 brass plug tonight.
