      Felton, DE
      Heater blower motor doesnt turn on, where to start?
      I really havent tried anything other than turning it on with the dash switch so i'm figured it has to be related to wiring/switch. I was wondering where the actual wires to the motor are so i can directly wire to it to see if the blower motor is good. Any ideas?
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Rockford Illinois
      Check for a bad fuse
      Clinton/Knoxville, TN
      Step 1) Check fuse
      2003 S10 de-Xtremed - 4.3, 5-speed, bagged, 18" Centerlines
      For Sale : ATS Spindles and SPC Adj. UCAs for G-body
      Felton, DE
      eh the fuse block is kind of not where i wanted to start as its kind of botched up being just about the entire car i've rewired to run from toggle switches. I was more curious about where the wires to the heater blower motor ar haha.
      Mountain View, CA
      Get busy with the multimeter lad.
      True T.
      My blog
      Newbury Park, CA
      They are attached to the blower motor under the RH aft fender.
      USA
      Quote Originally Posted by Shawn MacAnanny
      Which vehicle ?
      You've got three listed.
      Camaro , Firebird , and Duramax Truck.
      Jeff Tate
      U.S.A.
      Felton, DE
      Oh I'm sorry, the 68 Firebird. I put a new heater core in it and i only saw one wiring going to where the blower motor went. Should there be two or does it ground through the body? I really havent paid much attention as i was more concerned with wiring the engine and such until now.
      So there should be how many wires going to the blower?
      The wires go to the switch panel in the dash from there?
      The switch pannel is fed from the fuse pannel correct?
