Results 1 to 9 of 9
Thread: Can't get idle speed down
04-02-2008 #1
- Mar 2005
- 34
Hey Guys- I am trying to help a friend tune his new motor. It's a 302 bored and stroked to 331. The specs i know are this: flat top pistons, Roller cam, gt40p heads, chinese made intake, demon 650 carb, shorty headers, msd ignition. He built it and it is his first motor ever. First real experience with a car actually. He asked me for help when he could not get it started. I have found that he had no idea where the timing was (he actually had no timing pointer on the motor). I used a dergree wheel and a piston stop to find tdc. And then made a pointer from a coat hanger cause he was not able to buy one. We got the motor to fire and it went to 2500rpm! Then i found that he left a 3/8 plug out of the intake just under the back of the carb. Of course a massive vacuum leak. Fixed that. Now, with the idle speed screw backed out, i have adjusted the idle mixture screws (all 4) and it still idles at almost 1200 rpm. Again, idle speed screw all the way out. Not even touching the linkage. If i got the timing right, its set at 12 btdc. That was done with a cheap timig light and a coat hanger pointer. Any ideas? And thanks for making it through such a long read. jason
