    Results 1 to 10 of 10
      Oct 2007
      orange county, california
      Very Confused - Driveshaft Length
      so im swapping an LT1 with T56 into a69 camaro. i had a custom driveshaft made for it. i noticed that when i slid the yolk of the new driveshaft into the tranny til it bottomed out, the the opposite end (rearend side) was about an inch and a half short of the differential side. I then slid the yolf out an inch and a half so it would reach the differential.
      Is this normal. i would of theought the yolk would be all the way inside the tranny... can anyone tell me if this is how its supposed to be or did they do the measurements wrong on my new driveshaft??????
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Feb 2006
      Brampton, Ontario, CANADA !!
      Sounds fine. Driveshaft needs to have some room in the trans tailstock to keep from pounding out the trans innards as the rear suspension articulates.
      cheers
      Ed N.
      Ed Nicholson
      73 VW Super Beetle "Sports Bug"
      95 Taurus SHO 5-speed -- new open-track beater
      England
      What is the length of the yoke ,and how much is going in the trans ?
      Central CA USA
      The rear axle moves in an arc, farthest away from the trans when the front spring half is level.
      1" is normal, 1.5" is getting a bit high, but probably ok.
      What you do not want is for the yoke to ever bottom out, damage will result.
      David
      Oct 2007
      Quote Originally Posted by paul67
      id say its about 6 or so inches long, with about an inch and a half sticking out.
      Everett, WA
      Sounds about right to me. As said before, there has to be some wiggle room for that driveshaft.
      The few, the proud, the crazy... the LT1 owners.
      Dunwoody, GA
      Is the rear end just hanging and the suspension in the rear unloaded or is it on jack stands? It doesn't sound too bad.
      Trey
      ~ Jon Hammond
      Oct 2007
      nope, not lift or on jacks, this is as is, sitting on the ground.
      Everett, WA
      Doode, I stumbled across this webpage you should check out: http://www.9c1.com/technical/info/driveshaft.htm
      Apparently to check to see if your driveshaft length is correct, just jam it into the transmission until it bottoms out. Then measure the distance between the u-joint and the pinion yoke. This should be less than 3/8". See below:
      Aug 2006
      Houston, TX
      I've heard a good rule of thumb is 1/2" minimum slip yoke travel for a mild build, and 3/4" to 1" for something that's got a lot of power and/or will be launching hard at the drag strip. Anything over 1" of travel at ride height and you might have to worry about the yoke to output shaft spline engagement.
