    Results 1 to 9 of 9
      some where's in Ohio
      help with twin turbo timing.
      I have a sbc 406, with twins, Old fast efi with a lt1 harness. 27lb injectors(yeah I know they are lil small),1000 cfm tb, Isky racing cam, 10.1 comp., edelbrock pro flo alum intake and performer heads.
      http://www.iskycams.com/timingchart....ng_chart_id=98
      Im kind of confused, well i should say kind of lost. Im having troubles figuring out what timing values to place in the fuel map, (map vs rpm) Im running a 2 bar map. When I set the dist I set it at 6 deg, like the fast directions said (hei ext coil)Now are the timing map values totals with the 6 degrees already added of do I have to add them ?
      And what is the max timing that I can run with pump gas, where would that go in the timing map??
