    Results 1 to 9 of 9
    Thread: Turboing a BBC
      Dripping Springs, TEXAS
      Turboing a BBC
      I am trying to figure out the best way to hook up two T61's to my 402cid Big Block Chevy. The motor isnt built yet so I can do what ever is needed.. I know I cant run high compression, I was thinking blow throw carb, but I have a friend that is dealing with that and it doesnt look good.. :(
      I was wondering if there is a setup I can put on my motor so that it would be very tunable and stable..
      Anybody have any ideas??
      Do they have a setup that is fuel injected that doesnt need all the smog crap, 02sensors,and all the wiring.. I was thinking about maybe a ramjet, but im sure if that would work.
      No Help huh??
      Jul 2002
      Mesquite, TX
      Have patience, Mike. You posted late last night and it's still morning. Someone will come around.
      Sorry, I guess I did get a little impatience.. :D
      Oct 2005
      Ferndale, WA
      All that so called smog crap is what helps to tune the engine and get readings so that the fuel injection can adjust accordingly. EFI is the way to go b/c of the ease of tunability. A carb hat is good but only with a carb that is prepped and tuned accordingly. Do your reasearch and I'm sure some more people will chime in. I don't know of anybody that offers a kit but fabbing your own or haveing someone fab a system for you is most likely what wil be needed. Plan on spending some $$$$ though especially with twins.
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
      I wouldnt have a problem fabbing up the turbo kit, I have made a couple for a friends that keeps changing his setup.. :D I was just wondering about the intake and fuel setup on the car.. Thanks for the info, I will do more research..
      Here is a good place to go for turbo info
      http://www.theturboforums.com/smf/index.php?board=20.0
      Turbos, 1700.00
      Hot Side, 1500.00
      Cold Side, 1,000.00
      Fuel System, 1,000.00
      The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
      yeah don't despair
      the FI set up can be just as easy as a carb
      especially for common apps
      megasquirt is a simple do it your self set up and a few sensors and your set, the 'smog' crap won't be there just what you need to tell the computer what needs to be adjusted and for turbo this might be the best way to go
