Results 1 to 9 of 9
Thread: Cooling Line question
03-17-2008 #1
- Nov 2007
- 62
Hey Guys this might seem like a silly question but can you run braided stainless steel hoses in place of the factory hard lines for your trans cooler or are the trans cooling lines high pressure?
03-17-2008 #2
Starting The Transformation
- Jun 2005
- 467
Yes, good quality SS braided line, properly fitted with matching connectors will work fine. I use them for that exact application.
JimDon't take a knife to a gunfight.
Half-Assed = Half-Fast
03-17-2008 #3
Originally Posted by DeltaT
Yep, sure can! Just need to get the correct AN fittings for the trans and radiator.1966 SS Chevy II/Nova. Just an F1 Procharged roller 408 under the hood. Chassisworks front end, Mini tubbed, etc, etc.
Proudly sponsored by Adam's Polishes. www.adamspolishes.com
"If it ain't got that whistle...It ain't a missle!"
03-17-2008 #4
- Nov 2007
- 62
thanks guys will do
03-18-2008 #5
- Nov 2006
- 33
I have a question about cooler lines that I hope you guys can answer. It has to do w/ stainless lines, the lines on the car are 5/16 and they run to the radiator. What I wanna do is install an auxilarly cooler but using nice AN fittings. My problem is I can't find any AN fittings to match my up w/ 5/16 lines. Only thing I can find is 5AN but there doesn't seem to be any fittings availible except for tube nuts and sleeves. Anyone else having trouble w/ 5/16 lines to some sort of AN fittings. I would like to be able to do both 4AN and 6AN.
Help!!!!1967 Oldsmobile 442 W-30 w/ Fuel Injected E Block n C head 400ci, 2004r, Global West Everything, 3:70 Ford 9in, B-body spindle w 12in rotors w/ Wilwood calipers and11in Ford Explorer Disc setup in rear!! Alot of work!!
03-25-2008 #6
- Nov 2006
- 33
I guess there is no answer when you use 5/16 line. It just that 5/16 line seems to be standard for transmission cooler lines, so what do you guys do for custom plumbing??? Any one use AN fittings?
03-25-2008 #7
