Thread: Prep for a new transmission
03-16-2008 #1
- Nov 2006
- 33
I am going to install a Bowtie Overdrive 2004r trans and one of the required steps before I install the trans it to flush the lines and radiator. Is there something I can by to do this??? The lines will be brand new but the radiator was used with a bad TH400. Other questions are, if anyone is using this trans or one like it, what kinda ways do you cool it? Stock radiator w/ auto trans cooler inside or the radiator w/ an external trans cooler or just an external trans cooler??? I don't wanna have any problems w/ this thing.
Ken
1967 Oldsmobile 442 W-30 w/ Fuel Injected E Block n C head 400ci, 2004r, Global West Everything, 3:70 Ford 9in, B-body spindle w 12in rotors w/ Wilwood calipers and11in Ford Explorer Disc setup in rear!! Alot of work!!
03-16-2008 #2If you had a transmission go bad you MUST flush any lines that were connected. Since you have new lines you will be okay there, but the cooler MUST be flushed. It's also not a bad idea to flush all the new stuff as well to make sure there's no debris in there.
I would run the lines fron teh trans to the radiator's built in cooler, and then if you want more protection run it to a plate and fin external cooler, and then back to the trans.
If you have a near-stock stall you don't need the extra cooler. If you have a very efficient converter you don't need the extra cooler.
If you have an inefficient high stall converter you must install an extra cooler.
You almost can't overcool the transmission. Almost.
03-16-2008 #3
- Nov 2006
- 33
Is there a kit I can buy to flush the lines and the radiator? Something w/ a cleanser to pump through the lines and radiator? The bad trans is gone and the lines and the radiator are off the car.
03-17-2008 #4
