Results 1 to 12 of 12
Thread: I need some simple help
03-05-2008 #1
- May 2005
- St. Augustine, FL
- 1,529
I'm looking at getting two new rear wheels for my car. Right now the rear has 15x7 with 3.5 inchs of backspace. I want a 8 inch wide wheel in the rear, but there is no room for the wheel to go towards the fender lip and there is two inches of room between the widest part of the tire and the inner fender lip. Am I right to think a 15x8 with 4.5 inches of backspace will work perfect?
Andrew Petty
03-05-2008 #2sounds right to me. your increasing the backspace an inch to make up for the 1" in width. if you left the backspace at 3.5 and went with the 8" rim, it would push the lip out an extra inch.
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
wir müssen Leben bis wir Sterben...
03-05-2008 #3
- May 2005
- St. Augustine, FL
- 1,529
Thanks! I was just checking to make sure. Wouldnt want to order wheels and make a simple mistake.
Andrew Petty
03-05-2008 #4Do you have drum or disc brakes in the back?
Even though your fenders have the room, you will want to 2x check that the brake caliper has the room too (if you have disc brakes in the back).
I just went thru the same issue with my 64 C10 truck. With 12" rotors on a 15x8 rally wheel, 4" b.s. worked for me. I wanted 4.5" b.s., but the caliper interfered with the back section of the rim.Rick
" Better to Be Lucky than Good "
03-05-2008 #5
- May 2005
- St. Augustine, FL
- 1,529
Drums.
Andrew Petty
03-05-2008 #6
