    Results 1 to 3 of 3
    Thread: Brake Lines???
      Miami
      Brake Lines???
      As I sit here waiting for my wilwood order to arrive (4 wheel kit)...I think about the brake lines for my 55' chevy project...Do I just order stainless OEM style or do I just make my own....
      Pro's - lines come pre bent ready to install
      Con's - Can't use an aftermarket company that sells colored tubes
      Suggestions?
      May 2006
      Orlando
      I was following your logic until you mixed the anodized word with stainless.
      anyway, if the 55 had stock discs than a prebent kit might apply but in your case how do you know a generic prebent system will work for your aftermarket setup? personally I think it is a leap of faith for you to believe that a prefab will work out.
      if you have time and are not intimidated by the job, do it yourself.
      da.
      david
      68 camaro 350 SS convertible ala prodigy customs
      - its as much about the journey as it is the destination
      Miami
      Thanks...What I meant was using something like these: www.protubeonline.com in a color...should not have used the word anodozed...
      I was thinking of using all black so the lines wouldn't be seen easily...
