    Results 1 to 13 of 13
      custom intercoolers?
      what companies are out there that make custom intercoolers. the only ones i can think of are bell and spearco, but i know there are others.
      thanks
      Feb 2002
      Springfield, MO
      Griffin
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      thanks, i'll look in to them as well.
      Sep 2002
      So. Cal
      Ron Davis Radiators..Killer work!
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Sep 2002
      So. Cal
      I didn't see anything on Ron Davis web about Intercoolers. Hopefully there still doing it?
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
      Apr 2003
      Central Valley, CA
      I had Bell Intercoolers make mine.
      Very happy with the performance, quality, and turnaround time (less than 2 weeks to my door for my custom design.)
      1969 Chevelle
      Old setup: Procharged/intercooled/EFI 353 SBC, TKO, ATS/SPC/Global West suspension, C6 brakes & hydroboost.
      In progress: LS2, 3.0 Whipple, T56 Magnum, torque arm & watts link, Wilwood Aero6/4 brakes, Mk60 ABS, vaporworx, floater 9" rear, etc.
      Jun 2005
      +1 for Bell. Came exactly like my drawing stated, angles and all.
      Jim
      Don't take a knife to a gunfight.
      Half-Assed = Half-Fast
      thanks for all the responses. i did look at ron davis, but like you said, there was nothing on thier website. maybe i'll give them a call. otherwise, i'm leaning towards bell. thanks again
      UK London
      Anybody know of air/water intercoolers that can sit part in the firewall and partly in the passenger footwell or behind the dash that can allow a passenger to be comfortable and be efficient.
      Also does any one make a conventional front mounted street radiator with a hole/s in the middle for a front mount F3/F2 Procharger or Twin 88's?????
      Dayton, Ohio
      Quote Originally Posted by Procharmo
      Check out the intercooler's on Wheel 2 Wheel's Nova. I believe that this is what you are looking for in an intercooler setup. http://w2wpowertrain.com/t-novabuild-2.aspx
      Jeff
      http://www.kodakgallery.com/67rscamaro
      UK London
      Sparky67 you should warn people before you direct them to sites with such extreme car porn!!!!
      Brilliant fabrication!!!!
      Its making me think. mmmm.
      Discharge from F3 procharger splits, one to the inner fender area the other to a front mount Air to Air. The Air to water intercooler's discharge exits the fire wall and merges with the air to air dischrge before entering the carb/EFI.
      A pair of electronically controlled butterflys at the intake and discharge Y points controls boost source depending on temperature.
      You now have a street car without the benefits of both methods of intercooling.
      Is it too complex? Not compared to modern engine manament systems!
      UK London
      Infact I think I'll give them a call and get the tape measure out. I have no inner wings andn if I can slot it along side the blower motor(heating) I can install it inline with the discharge from the front mount. It will only be a few feet extra pipeing plus I get to exit from the cowl area to the carb for that symetrical look.
      With these two intercoolers the charge will be way below ambient.
      Dayton, Ohio
      I believe W2W used to be a sponsor here, but I just don't seem them in the list. Anyway, if you want the best in the business then they are the ones to call.
      Jeff
