- Aug 2004
- Pittsburgh, PA
- 316
Rebound travel/upper CA bumstop questions
Im running SPC adjustable upper arms with Howe tall ball joints. The rest of the front suspension as follows, stock lowers w/GW bushings, circle track adjustable spring shims with 500lb 9.5" coils. The shocks are Eddy IAS classics & a Rancho swaybar.
At freeway speeds the front of the car kinda hovers when you run into section of road that "falls away", you can kinda feel the wheels rebound but it take a second for the nose to settle. I know that part of it is a lack of rebound damping but would excess rebound travel add to this?
I do intend to measure this before I take any action, just as soon as the working conditions get a little better here. I read in a previous thread 2" of bump & 3" of rebound are pretty common goals to shoot for.
Since there isnt good provision for adding a bumstop for the SPC arms what do you guys think of using nylon limiting straps like the 4 wheelers do?
Shane
