Results 1 to 16 of 16
Thread: New G-body member
- Feb 2008
- Carthage Missouri
- 3
New G-body member
Hello all, I just found the forum yesterday so I haven't had a lot of time to read old post etc. But I will be building a 1985 Buick Regal at some point in the future and think I would like to go the "pro-touring" route with it. It currently has a locked up 3.8/th200 in it but it will soon have a stock Buick 455/TH400 to make it a driver.
If you guys could point me in the right direction with the build I would appreciate it. I want a good handling car, it has to be 455 powered and I would eventually like to have a 6 speed manual behind the 455.
What are some good sites/old posts that discuss G-body mods? Do G-bodies have good potential for Pro-touring builds?
Look forward to asking questions and sharing my progress.
02-23-2008 #2
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
Welcome CJ! The G-Body platform is great for a PT style build. Lots of options. Good luck!
02-23-2008 #3Welcome we need more g-bodies
Awesome I am building a 85 PT regal myself. Glad to see more Regas
1985 T-type regal
2001 Cadillac Catera
and some big firetrucks
02-23-2008 #4Welcome to the board.
87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
02-23-2008 #5Welcome aboard! Yet another g-body owner. I am myself building a Cutlass.
You mentioned wanting to go 6 speed. What I did with mine is go with the aftermarket T56. It will bolt up anywhere a 3-4 speed was. I went with mechanical clutch linkage on mine...I didn't care for the hydraulics. 3rd gen f-body pedals are almost a bolt in. Just find a flywheel and bellhousing for the Buick 455, add a matching clutch/pressure plate for the fw/bell housing and bolt it up. You'll need to shorten your driveshaft or have one made.
That's just one option among the many. If you want more details let me know.
DougDoug Gulley
02-23-2008 #6
