      Dec 2007
      British Columbia, Canada
      Using an air flange tool
      If I use an air flange tool for putting in quarter patch panels, will the flange tool cause the existing quarters to warp at all? Or should I go about 6", then stop, then go again etc? Any advice would be great.
      not gonna warp 1/4s do entire length
      Aug 2006
      Belforest, AL
      Flanging the quarter has the ability to de-arc the quarter panel. Basically when you flange it, it will try to force the quarter panel flat.
      Imagine taking a piece of sheet metal that has a curvature to it. Then imagine what the metal would do if you put a 90º bend in the panel perpendicular to the curve. Essentially that is what you're doing when you flange a quarter panel.
      Todd S.
      "I like to race school buses..."
      Houston, Tx
      Quote Originally Posted by LateNight72
      The effect will be pretty minimal... you are only flanging about 1/2" each time.
      Dec 2007
      Thanks for the replies guys. This is the next portion of my project.
