Results 1 to 20 of 30
02-20-2008 #1
- Nov 2007
- 10
Six piston or Four piston Wilwoods?
Hi everyone, I'm over from Team Camaro.
You guys are the experts. I ordered the 12.2" Dynalites 4 piston front/rear. Now after reading 100's of posts and my head about ready to explode, I'm having second thoughts.
Should I go with the 6 piston Superlite on the 12.2 for the front for an additional $400? (Funny the reason I went with Wilwood over Baer was because of $$$$)
Is it that big a difference? I will be street driving this car, but maybe some day Ill take it to a track, for fun, a couple times.
Thx for your imput. Chad
02-20-2008 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
I think the (6) piston 12.2" set up is the coolest thing to hit the brake market in a while. No 17" wheel clearance issues, and all the bling and increased stopping power.
We can upgrade the calipers. If it were me I would.
Also, I am buying a bulk of those calipers and will be doing a special on the (6) piston upgrade in a couple days.
02-21-2008 #3I'd do it. $400 isn't too bad, and if you are going to splurge on something, do it on brakes. You just can't go wrong.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
02-21-2008 #4Another option: you could put you a DIY style Hydroboost on there and get all the stopping power you need. Unless you just "want" 6 pistons. You don't have to buy the high dollar kit if you don't mind doing a little fab work to the bracket. I put Hydroboost on my ride for about $135 or so. $75 for the J/Y unit, $40 for new lines from a 81 Toronado Diesel, free PS pump with late model O-ring style pressure outlet, plus some incidentals. I also added a late model steering box with O-ring connections (quick ratio).
I don't know Wilwood's line in and out, but I would verify that total piston area actually increases with the 6 piston over the 4. If not, then I don't think it would be worth it to upgrade for the extra $ involved.68 Camaro, 406, T-56, Hydroboost, IROC box, SC&C Stage1+, Hotchkis front springs and bar, Speedway Engr. rear bar, Varishocks all 4's, Vintage WW V48's
48 Ford F-1 pickup, 355, 700R4
02-21-2008 #5
- Jan 2006
- Oregon
- 1,773
