Results 1 to 12 of 12
Thread: 69 Camaro RS/SS wheel backspace
02-19-2008 #1
- Feb 2005
- Naples Florida
- 12
Hello I am new to this forum and was wondering if anyone knew if a 245-45-18 or 245-40-18 would fit on the front of a stock suspension 69 big block camaro..And what backspacing to use?? I have already figured out I can get a 275-40-18 on the back but cant get the front figured. Thanks for the help!!
02-19-2008 #2Both those will work perfectly on the front of your '69.I'm sure several other wheel experts will chime in here.
As far a b/s is concerned,a 4.75" or 4.875" b/s will work nicely on an 8" wide wheel.5" will work fine as well,you'll need to measure however since every one of these cars are slightly different.
On the rears,a 5.5" b/s on a 9.5" wide wheel should be fine with either 275/40's or 285/40's.'67 Buick Skylark GS400 funny car "Ingenue" 8/10 HRM / Gasoline (Swedish) cover & feature 2/12
www.buickfunnycar.com
02-19-2008 #3you'll have no problem with those sizes, i'm running 245/40-18 on the front with a 2" drop and have no issues...
Jeff J. aka JJ
1969 Camaro
1952 Chevy Truck
wir müssen Leben bis wir Sterben...
02-20-2008 #4
- Feb 2005
- Naples Florida
- 12
Thanks to all for the reply,but the problem I am now faced with is that I want to use the billet speciaties Vintec Dish wheels but the max bacspacing on a 18 x 8 wheel is 4.5" does anyone know what size tire I can use with that backspacing?
I would appreaciate any help I can get Thanks!!!
02-20-2008 #5A 245/40/18 is a good fit!!!
Steve Martin
67 Camaro RS
66 Chevelle
02-20-2008 #6
- Feb 2005
- Naples Florida
- 12
Sorry to be redundant but i want to make sure that a 245/40/18 will fit with a 4.5" backspacing on the front?????
Tony
02-20-2008 #7Your gonna rub some stuff with that backspace. You really need that 4.75 - 4.875 backspace on an 8" wheel.
Eric
69 Camaro - LT1 w/ 700R4, DSE springs, swaybar and Konis. Still rockin' it old school with 15" wheels and 60 series tires.
02-20-2008 #8Correct.No matter what size tire,4.5" b/s will be very tight...expect rubbing.
02-20-2008 #9
