    Results 1 to 11 of 11
    Thread: Ring Gear
      Ring Gear
      Who sells "thick" ring gears so that you can run a 3 series gear ratio on a 2 series carrier.
      I want to run 3.55 or 3.73 on a 2 series posi? Any help is appreciated.
      JEFF
      1968 Camaro RS/SS - "BLUE"
      www.fquick.com/jmd68rsss
      Jul 2002
      Mesquite, TX
      Summit's got some, or Mr. Gasket makes a spacer so you can use a regular 3 series gearset.
      Dec 2002
      Lost Wages, Nevada
      DO NOT USE a ring gear spacer in a performance application.
      Not to mention... that the only way you will be able to do this with any GM differential (with the exception of the 7.5") is to use a ring gear spacer... or to change out the complete differential carrier, meaning, posi - limited slip - torque sensing - locker... etc etc.
      It is most likely best that you cahnge out the differential for a new unit not only for the correct flange offset but to a stronger unit as well. Depending on the differential you have... the land speed racers are always looking for 2 series carriers/posi's... so you can sell what you have to re-coupe monies for what you really need.
      But... To answer your question correctly, the first time around... which differential and which POSI are you refering to ??
      It is a 8.2" Eaton posi out of a 1968 Nova w/ 2.73 gears.
      I have read the spacers are not a good idea. But I have been unable to locate a place selling "thick" gear for the for this 2 series carrier.
      Thanks.
      JEFF
      Jul 2002
      Mesquite, TX
      Summit's got one set of gears - 3.73s, if memory serves, that fit a 2 series 8.2 carrier.
      I called Summit and Randy's Ring and Pinion, neither carried a Thick gear for the 8.2" GM rear end.
      From talking to the tech line, for my application, a spacer would not be too bad. Street driven car, flashlight drags once or twice a year and less than 400 HP.
      If anyone knows of a vendor, please let me now. Could you weld the spacer to the ring gear?
      JEFF
      Jul 2002
      Mesquite, TX
      This looks to be a thick gear for the 8.2:
      http://store.summitracing.com/partde...5&autoview=sku
      "Gear, Ring and Pinion, 3.73:1 Ratio, GM, 8.2 in., 10-Bolt, 2 Series, Set"
      Yes it does. Thanks for the link. I might have thought the Tech line could have found this.
      JEFF
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by JMD68RSSS
      Quote Originally Posted by derekf
      That is because what you are looking at is a type-o. USGear/Strange does not make series swap gear sets for the 8.2". Never have... never will.
      So, in short... they are not available through any manufacturer/vendor... unless you have them made. You got 8k laying around ??
      And no, you can not (should not) weld a spacer to the ring gear. Nor would I recommend that you beat on them at the street/flashlight races. If the chassis never hooked up and you didnt pound the trans... they will live... but its a gamble either way.
      Chicane67,
      I am certainly a novice in this area. But the gears derekf posted the link to say they are for a series 2 carrier. Why would these not work?
      And, if I had $8k laying around, I would not be asking these questions to work with my next to nothing budget.
      Thanks for the input.
      JEFF
      Dec 2002
      Lost Wages, Nevada
      ... But the gears derekf posted the link to say they are for a series 2 carrier. Why would these not work?
      Because it is a type-o. What Summit is advertising... does not exist. They do not make a two series, 3.73 gear set.
      They have never produced a two series 3.73 gear set... and they never will.
