    Results 1 to 20 of 25
      Feb 2008
      Sesser, Il
      86 Cutlass g-machine
      My name is Doug Gulley and I have an 86 Cutlass I'm building into a Pro Touring driver. It's a long term project.
      I'm building a 383 SBC with Accel SuperRam, 58mm tb, 30# SVO inj., AFR 190 heads. I'm currently deciding whether to use hypereutectic or forged pistons and which cam to run. I have a Comp 218*/224* .495/.502 112* hyd roller... deciding on if I should got to a 224*/230* hyd roller or jump to a 230*/236* solid roller. Hmmmm....
      Tranny is a Tremec Aftermarket T56 with a Spec Stage 3 clutch and mechanical linkage.
      For the front suspension I'm running Moog 5662 (IROC 702#) coils and the IROC 36mm swaybar and XH steering box. GW upper arms and GW bushings in the stock lower arms. B-body spindles will mount red powdercoated C5 calipers with drilled/slotted rotors.
      The rear suspension pieces are yet to be determined but will be upgraded stock type parts. LS1 rear disc will also be added.
      Wheels and tires are yet to be bought but I have my heart set on Vintage Wheels Works V40's in 17x8 & 17x9-9.5's with 275/40 & 245/45 tires. Backspacing yet to be determined.
      The exterior will look sorta "old school" with black paint, 86 442 rear spoiler, 442 style 'glass hood and updated sidepipes.
      I'll have lots of questions along the way but nothing members cna't handle. Maybe I can answer a few along the way.
      Pro Touring rules!!!
      Doug
      Washington, MO
      Welcome Doug! Post up some pics of the project.
      Feb 2008
      Sesser, Il
      Thanks Tony.
      My car is really nothing to look at right now. Basically just like any other run-of-the-mill Cutlass with the interior out and sitting in the back yard. The blue interior is out and I'm presently cleaning up the Claret (burgandy) interior I'm putting back in. When I get the dash ready, I'll pull the blue dash and run my Howell harness for the TPI and install my clutch/brake pedals. Then it'll be ready for the burg dash and rest of the interior. I'll add 4th gen f-body seats in matching upholstery.
      I am compiling pictures (non-digital) of all my steps along the way, I just don't have a scanner to send any pics as of yet.
      Doug
      Doug Gulley
      dayton, oh
      awesome to see some more of these... at least i know i'm not completely crazy... :D
      dave.t
      74 Javelin AMX - stocker
      Feb 2008
      Sesser, Il
      LOL... Yup. As Waylon Jennings sings... "I've always been crazy but it keeps me from going insane......"
      Doug
      Doug Gulley
      Feb 2008
      Sesser, Il
      Jackfrost....I was checkin out your webpage.....DEJA VU!!!!!!!! I've seen my car in those same stages!!!! Dash......gone!!!!! And mine is about to go thru that yet again. I found a better body so now my 86 burgandy interior (dash and all) will have to be re-installed in my other car...
      So....no....you're not the only "crazy" one. I'm lovin it!!!
      Doug
      Doug Gulley
      Washington, MO
      Check this one guys:
      http://www.fe3xolds.com/
      Looks pretty mean!
      dayton, oh
      Yeah, Angelo's car is pretty sweet. very clean.
      the only one cooler is the original FE3X in the GM museum. before pro-touring was even a concept! :D
      http://black85.oldsgmail.com/fe3x.htm
      dave.t
      Feb 2008
      Sesser, Il
      I've talked to Angelo a few times when I was on the Olds list. It is sweet.
      Doug
      Doug Gulley
      b-ville MD
      86 442 as well
      welcome aboard
      North Jersey
      Hey Doug, welcome to the site! I remember you from a few years ago on the Monte Mailing List. Glad to hear you still have the car, and still wrenching on it. Good luck with the project!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Feb 2008
      Sesser, Il
      That would be me Steve. Good talking to ya again.
      It's not actully the same car...just another like it. My 84 was rusted so badly all over it was more feasible to replace the whole car rather than the rust. I'm putting everything I had on it onto the 86 and refining as I go along. It's not my daily driver anymore so I can take my time and get it all sorted out properly.
      Doug
      Doug Gulley
      Rolla, MO.
      Welcome aboard
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      Eastern Virginia
      Welcome G body brother. Definitely post some pics.
      Scot
      86 Monte SS
      May 2006
      Orangeville, Ontario Canada
      Do you have any info on mounting the C5 calipers to the B-body spindles?
      1987 Monte Carlo Super Slow - Super Worn Out 355, Carb, Giggle Juice, 3" Duals, 200-4R & 4.56s
      1987 Turtle Buick - T63e, 83s, FMIC, MPE DP, PowerLogger, MAFT Pro, 4" Single, ProPain & 3.08s
      2002 Crapmaro B4C - LS1, A4, SLP Lid, DiabloSport, Cutout & 3.23s
      2007 TrailBlazer Super Slug - LS2, A4, AWD, Tune, CAI, Exhaust & 4.11s
      If you didn't build it, it's not yours.
      Feb 2008
      Sesser, Il
      motorheadmike... yes I do have that info. I've got the stuff to do it, I've just yet to get mine installed.
      I'm going to use an alum bracket to adapt the C5 caliper to the b-body spindle. I can't remember where I got my bracket but if nothing else I could make a full scale tracing and snail mail it to you. I might be able to did up the dimensions online also.
      There are 2 ears to cut off the spindle so the adapter bracket will sit on the spindle correctly. Basically the ears for the old caliper needs removed.
      Bolt bracket to spindle and PBR caliper to adapter bracket.
      It's that simple.
      To mount the rotor you remove the brake area from a rotor and use the rest as a hub for the Vette rotor. The Vette rotor doesn't have a hub.
      If I can find more info for you I'll send it along to you...it's not that difficult to do tho
      If you are mounting these spindles to a g-body then you need to use either a Global West or Hotchkis upper a-arm. Other companies may also make them. They are shorter to give better angles for the suspension geometry. It's hard/impossible to align using the stock g-body spindle.
      Doug
      Doug Gulley
      Brookfield, WI
      More G-bodys! yessss.....
      Welcome!
      Gino T. Rinaldi
      [email protected]
      87 Buick GN 52k miles, 11.40@121 Pro Touring Frame Off in process
      87 Buick Turbo T 7k original Miles
      86 Buick Regal T-Type Turbo WH-1 1 of 463
      North Jersey
      Quote Originally Posted by 86Cutlass383SR
      Doug
      That's great! Sounds like the same thing I did a few years ago. My original car was a super-rusty 199K mile '85 SS, that we had the whole drivetrain and suspension in. We chopped that car up in November of 2003 after my wife bought this clean '88 SS for my 30th birthday, and transferred everything over to this car.
      Again, good luck on the transformation, and be sure to post pics when you can!
      2006 Infiniti G35x
      WNC
      I'm glad you're here Doug. I've got an '82 Cutlass that I'm looking to give it a similar treatment. Mine is frame off right now prepping for paint and wanted to order the full AirRide kit but I really don't know what to expect. I notice now that AirRide has some spindles added to their kits that are like the APC spindles and their full kit is the way to go but ...dam$$...at around $6200 for the full kit, what can you do?
      May 2006
      Doug,
      I have the B-body set up already; my kit was put together by Robert Adams years ago. I like it, but there is an upgrade coming to the rear and I want the front to match.
      This C5/B-body setup sounds like the same process as the LS1 brakes onto the stock spindles.
      You have a PM.
      Thanks!
