      Aug 2006
      Connecticut
      Nova Subframe Connector Questions?
      Im looking into getting a set of subframe connectors for my 74 Nova and looking to see which ones are the most popular and the ones that are good. I wanna go bolt in because I wanna try not to mess with the car underneath..but not sure. So bolt in or Weld In? also when welding will the floorpans have to be cut as ive read from the other posts? and lastly which brands, Hotchkis, Global West, DSE, or Competition Engineering? Thanks for the help
      GTO, 2009 Camaro or maybe a pro-touring machine? Only time will tell. The Nova for now!
      Aug 2003
      We install and sell a lot of Hotchkis. They fit the best of any I am aware of, and tuck very nicely. The do require 4 plug welds at the rear of the connector, but bolt in the front. I have not installed any connectors that bolt at the rear that did not do more damge then 4 plug welds to the original car. No floor cutting or hammering needed with the Hotchkis. We stock these.
      Here is a set we just did ion a Camaro we just finished. What i like is you can barely see them in the profile shot
      Fontana, CA
      The Global West Connectors also require welding on the rear but bolt at the front. No Floor mods needed. No interference with the leaf mount. The DSE ones aer welded into the floorpan and require a LOT of fab and welding. The CE bolt ins work, but not the best and are a PITA to get lined up with the leaf mounts and the frame (sometimes). I would go anything but the CE pieces and avoid the DSE if you don't want major surgery on your floorpans. To me it is between Hotchkis and GW, and last I checked, the GW pieces were priced better.
      Nick R.
      IL/TN
      we have the GENII/Alston and solid body bushings to go with them
      https://www.protouringf-body.com "doing what they say can't be done"
      Nov 2004
      Dallas Texas
      subframe connecters
      here is a link (its also a sticky on this section) to IMO the best out there -although there is alot more to the install https://www.pro-touring.com/forum/showthread.php?t=7917
      and when installed theyre pretty much invisible and have no ground clearance issues , in fact i have them in my 69 bird
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Dec 2007
      British Columbia, Canada
      I have the Global West ones. Haven't put them in yet, but from what I understand there's no body mods and you weld them to the frame. The look sweet!!
