02-10-2008 #1
Had a fuel pump problem yesterday.....
Hey guys,
I had a bit of an issue yesterday and maybe someone here could shine some light on it. I took my Camaro out for a nice, long cruise since the weather has become very nice in the last few days. It was probably mid-70's, not hot by any means.
The car drove great the whole drive, then when I was heading back home I made a full-throttle blast getting onto the freeway and the motor fell on it's face at 4000 rpm. It was like hitting a rev limiter and did this in every gear I tried. I took the car home and starting doing some checking.
What I found was my fuel pump sounding very high-pitched and almost making a "honking" sound when I turn on my key. The pump usually has a deep sound when it primes the system. I realized right there that it was fuel related and let the car cool off for 20 minutes or so. The pump returned to it's regular tone, and I went to the gas station to fill up since I had about 1/2 tank left.
I filled up and took a little drive to see how it would run. The power had completely retuned and pulled very strong up and above 6000 rpm. I'm not really sure what caused the problem. The fuel tank was pretty warm to the touch, but not hot. I do have a dual fuel line system that retuns all unused fuel from the rail to the tank, and a fairly large Walbro 255L fuel pump. I'm wondering if all the low rpm cruising caused excessive heat in the fuel and eventually overheated the pump.
The other thing I can think of is that my Magnavolt (fuel pump booster/relay) could have gotten too hot and was reducing voltage to the pump. Unfortunatley, I did not have my volt meter handy to check the output when it was going on. The Magnavolt was pretty warm, but so was my ECM that is located right next to it.
So, what do you guys think? Do I need a single line system to help reduce heat? FWIW, this is on a Magnacharged LSx powered '67 Camaro that dyno'd at 505 rwhp.
Andy
