      window felt and glass on 69
      ON a 69. should you install the outer window trim/felt that goes on the top of the door before or after the glass is put in?
      Fred Bartoli
      Altronics Inc
      www.AltronicsInc.com
      Project Full Circle -> www.altronicsinc.com/camaro
      May 2002
      Northern California
      you don't have to but it makes it a bit easier.
      i usually install the glass then the felt. Just leave the bottom glass stop out till you get the felt installed.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Nov 2007
      Galena, MD
      install glass first
      Rockford Illinois
      When you go to install the screw at the end of the felt to hold it in place. A good trick is to use a piece of tubing to guide the drill bit to the right place and also keep the drill from slamming into to panel.
      This works for other things you will be drilling when you get to them also while doing the interior.
