Results 1 to 8 of 8
02-18-2008 #1
- Jan 2006
- Garwin, Iowa
- 241
MARK VIII and SPAL PWM wiring question
Hooking up my mark viii fan and spal controller with override switch/ 70 amp relay from Jabin at gmachinz. The relay is pretty self exlpanatory, but wondering about the power wire to the fan from the relay. Should this be spliced into the power wire from the controller to the fan? I'm assuming this is correct and the fan then grounds through the controller when running off the relay. Anyone used this setup? Thanks, Nate
