    Results 1 to 12 of 12
      Jan 2000
      Thousand Oaks California
      New Product - DSE 2nd Generation Camaro / Firebird Roll Cage Kit
      Detroit Speed and Engineering announces its 2nd Generation Camaro/Firebird DSE Roll Cage Kit. The exclusive design follows interior lines of the car, does not interfere with interior comfort, and packages close to the headliner and back window glass. The bars are pre-notched to save you time. The rocker panel floorplates and trunk floorplates for mini-tubbed or stock trunks are pre-bent to decrease overall installation time, as well. This roll cage will provide additional safety along with increasing chassis strength. The unique removable cross-bar allows you to use the back seat for rear passengers, if necessary. The cross-bar has CNC machined stainless steel clevis and stainless steel quick-pins. The roll cage is 1-5/8" x .134" mild steel tubing while the removable cross-bar to access the back seat is 1-5/8" x .120" mild steel tubing.
      The roll cage requires welding and does not fit convertibles. You can purchase the roll cage through DSE for $650.00
      For more information, contact Detroit Speed and Engineering, Inc. at 704-662-3272 or on their website at www.detroitspeed.com.
      Larry Callahan
