      Aug 2006
      Cibolo, TX
      Front sway bar mounting questions
      Simple question - I redid my front end with SC&C's Stage 2 Kit a while back, and I am not sure I "adjusted" my stock front sway bar properly. I snugged the end links of the sway bar down when the car was still on jacks.
      I am now thinking this should have done when the car had the suspension loaded.
      Can somebody give me the "sway bar tuning 101" and let me know how to do this properly on an 87 Buick Regal Tubo T?
      Rob
      Dec 2007
      Pittsburgh, PA
      when you say "still on jacks"...where were the jack stands? On the frame? or on the lower control arms?
      Mark
      70 Nova, Hotchkis springs and sway bar GW uppers, Bilsteins, , sub connectors, Smooth firewall hidden wiper motor, LS1, 425 rwhp, 175 NOS Ridetech 4 link HQ Coilovers, Mini tubs, 315's. Ridetech billet gas cap, FLT level 5 4L60E, Yank
      Aug 2006
      Cibolo, TX
      Quote Originally Posted by 70LS1NOVA
      The jackstands were under the frame.
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      Dec 2007
      New York
      Quote Originally Posted by Turbo Rob
      Rob
      There is no sway bar tuning or adjustment. And I don't think it makes any difference if it's on stands or not. The sway bar does not come into play unless the car is leaning such as in a hard turn.
      May 2002
      Northern California
      Quote Originally Posted by Ranaexcavating
      I agree, if the bar/frame bushings where lubed properly it should not make a difference.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
