Thread: Blow Off question?
02-06-2008 #1
Starting The Transformation
- May 2006
- 110
Blow Off question?
I'm redoing my intercooler piping and wondering where the proper place is to mount my bypass valve? Before or after the intercooler. I have see it done both ways. Which is the right way or does it matter?
02-08-2008 #2They will both work just fine. The purpose of the blow off valve is to protect the blower from spiking pressure when your throttle body slams closed. This pressure will be pretty close to the same at both points. One could say the shockwave starts at the throttle body so put it there. I don't think it will matter either way. Unless your intercooler collapses...
Originally Posted by 69Bbird
Ron DeRaad
68 Camaro RSx
Darton Sleeved LS9 - 434ci (4.155x4.00)
AFR LSX245 Heads (12:1cr)
660hp/588tq
02-09-2008 #3Before the intercooler is best. Most of the hot are is is released while not under boost. This means your intercooler will not be heat soaked.
02-09-2008 #4Good point, my brain was in turboland...
Originally Posted by 67 caprice
I forgot about the constant venting style blow off valves. With a belt driven blower and a constant venting blow off, I agree. In front.
One thing to remember, if your not in boost your not generating heat. Unlike a turbo, since centrifugal belt drivin supercharger operates on RPM, it will always be generating some kind of heat from boost. If you have very mild boost (less then 10psi at max rpm) you will only be generating a few psi at idle to 2000rpm. Minimal heat. If you have a blower that puts out 10-15 psi off idle then it would be huge heat!!!Ron DeRaad
68 Camaro RSx
660hp/588tq
