    Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    Results 61 to 80 of 146
    1. #61
      Central CA USA
      Thanks for the photos! I was thinking of doing something similar, or I do have an old truck that I could strip down for a piece of the frame, then add legs and perhaps lay a pair of I beams or square tubes on top of them if it's not flat enough.
      David
    2. #62
      May 2002
      Northern California
      Looks good Scottzilla. Did you go through Northern for the casters? Those roll nice.
      !!Off topic!! but did a guy named Steve get in touch with you yet? He bought my 69 Nova and he wants to do an LS/T56 swap but im swamped. He's in your area. BTW, hows business been?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    3. #63
      May 2007
      Houston, Tx
      this has helped enormously reading through it all...thanks to everybody who has contributed!
      Colin Russ
    4. #64
      Jul 2008
      Quote Originally Posted by SVTforme
      Almost there.. there was minimal warping with this method, although there was a bit on the short overhanging end pieces. Will have to reverse this by some heat and force on the ends. Nothing major though. Had to brush up on my MIG skills as I have only been using TIG for while now. TIG would just make the warping much worse.
      The braces are thinner walled than the main pieces - just extra material I found sitting around. Should have this up and running under the car within the week.. can't wait. The Carr-Lane leveling feet (part CL-8-SLF) work perfect.
      Also set this up so I can put an 1" thick or so sheet of plywood in between the braces to drop the plumb bob on. A 4x4 sheet will fit exactly in between the two middle sections.
      I don't understand how TIG would make heat input worse than MIG????
      You have a foot pedal to control heat with TIG. Care to explain???
    5. #65
      with tig, you have constant heat going into the weldment, where with mig you cant stich weld it to keep heat to a smaller haz
    6. #66
      Jul 2008
      Well i guess i have to know what sort of TIG you would be using b/c what you said just doesn't make sense to me. Wether you MIG for 1in and then skip 2in weld 1in and keep repeating that pattern. Once the trigger is pushed your a Xamps. With TIG (I have a Miller Dynasty 300DX) you can set the pulse, background current, etc..etc. Heck at the very least you can rock the pedal.....
    7. #67
      yes tig weld is cooler, however mig done properly will have less of a heat affected zone then tig
    8. #68
      Jul 2007
      Posting these just to give ideas and make everyone sick...
      Rest of the shop pics can be found here: http://www.race-dezert.com/forum/sho...d.php?p=260219
      Chris
    9. #69
      Jul 2008
      Thanks for that man...................no really........................................than ks.
    10. #70
      Motorcity, Canada
      Finally.. a post with the chassis jig in action. Even painted it for you David . Thanks everyone for all your input! The car is just sitting on there on wood blocks and on rollers for now awaiting the body and suspension cradles. Likely time to start a progress post now that I am done this detour.
      Rear adjustable IRS cradle in progress:
      As for the note about TIG vs MIG - the heat affected zone is the key. Think about the speed in which you typically TIG a part vs MIG on the same part (TIG is slower at least when I am behind the torch). MIG is typically faster, meaning the heat transfer to surrounding areas is going to be less (via the pricipals of conduction). When building this jig, we definitely saw a noticable difference in part distortion when comparing TIG vs. MIG. The degree to which they are different will most likely vary with operator skill. As David called it, we spent a considerable amount of time with the torch attempting to get rid of the distortion on the parts after welding. While we are only talking mm here, it is still enough to throw the flat surface off when you are looking at a 12 ft long part.
      Craig
      1968 Torino GT 4.6L S/C T56 IRS x2
      www.twintorino.com
    11. #71
      Rockford Illinois
      Now that is a nice table, the paint really does make all of the difference when you look at the car. Seeing something new in the pic always gives a direction for your imagination to go. If it all looks like it needs attention the inspiration for others is not visible.
      It looks like you have the stance, now it's just keeping it without problems
    12. #72
      Oct 2005
      Ferndale, WA
      Ohhhh DAddy!
      Chris[/quote]
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
    13. #73
      Dunwoody, GA
      so after welding the jig together, how do you determine if it's warped, where it's warped, and by how much? You have to measure from somewhere that's known to be true, correct? Thanks guys
      Trey
      ~ Jon Hammond
    14. #74
      Alabama
      I built one out of 4" ibeam basic 3 mid beams/2 side beams about 41"x11' .the mid beams are bolted/dpinned so you can move the ends in. I did dpin/bolt holes every 2".turned out great. have a solidworks model/ or pics if you are interested.
    15. #75
      Greenville, IL
      Quote Originally Posted by STREET ROD
      Pics would be great.
    16. #76
      Alabama
      I hope the pictures are far away enough to get a good idea of the jig
      I may take some more farther away.
      Attachment 25689
      Attachment 25690
      Attachment 25691
    17. #77
      Nov 2007
      Moore, Ok
      Dunno if this will help but here's a few pics of my table
    18. #78
      Jul 2008
      swwwweeeeeeettttt
    19. #79
      Central CA USA
      I have a question on table length.
      I can get a truck frame for free and am thinking of making a frame table out of it. It will be super heavy and a bit narrow but I have a forklift and can place square tube sections across it for more width. This thing is STOUT! allready has crossmembers riveted in and the frame is double thickness!!!
      I'm thinking that to do a Camaro you need 14' to 15' long? I can always cut some off the ends if it's too long.
      Thanks, David
    20. #80
      Mar 2004
      Mid-Michigan
      Quote Originally Posted by David Pozzi
      Thanks, David
      Actually you only "need" a foot or so longer then the wheelbase. As long as there is enough length to set up the tire/wheel combo you should be good.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
