    Results 1 to 8 of 8
      Miami
      Complete Front End Rebuild
      getting ready to buy all the parts I need to rebuild the front suspension on my 55' chevy...Would the list below be complete? If I missed something please list.
      See list:
      Pitman Arm
      Center link
      Idler Arm
      2 outer tie rod ends
      2 inner tie rod ends
      2 tie rod adjusting sleeves
      2 stabilizer links
      2 idler arm bushings
      control arm bumpers
      4 lower control arm bushings
      4 upper control arm bushings
      2 control arm shafts
      2 upper ball joints
      2 lower ball joints
      Oct 2006
      Phoenix, AZ
      One thing I didn't receive when I bought the rebuild kit for mine was the grease caps that go on the tie rod ends, ended up having to buy those seperately. I bought my kit from PST. So make sure you're getting those. Don't forget new cotter pins and castle nuts!
      A friendly reminder...If there's a chance that you'll use any aftermarket control arms/steering box or parts of that nature, keep that in mind when buying your stock stuff so you don't have duplicates. Wonder how I learned that lesson....?
      Hope this helps!
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Miami
      I am doing tubular uppers and lowers and they come complete.
      I will delete the items that I get with the control arms - bushings, shafts and ball joints.
      I just wanted to make sure I am not missing any items I'd need...like castle nuts, pins, etc...
      Will be doing a new box, but that's not in the $$ plans yet!
      Nov 2004
      Dallas Texas
      Quote Originally Posted by jy211
      See list:
      Pitman Arm
      Center link
      Idler Arm
      2 stabilizer links
      control arm bumpers
      2 upper ball joints
      2 lower ball joints
      I looked and looked again, you forgot the Muffler bearings!
      J/K good list i might also recomend to look closely at the control arms when you have it apart, and any other parts you will be re-useing for hairline cracks ect , when i rebuilt the front end on my 70 Torino i found several in the control arms requiring replacement and it is 15 years younger and it was at least 10 years ago(course it was a ford)
      better safe than ...........
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Oct 2006
      Phoenix, AZ
      Cool, sounds good. I think you've got everything necessary. I originally started out thinking I would be doing a stock rebuild and had purchased the kit to do so, when it was all said and done I think the only think I used was the tie rods and adjusters and the idler arm. Oh well, I have a habit of making expensive mistakes like that, but I'm learning!!
      Jeff K.
      New York, NY
      sway bar bushings?
      Miami
      Quote Originally Posted by jerome
      sway bar bushings?
      Those will come with the hellwig sway bars...
      Miami
      Pitman Arm
      Center link
      Idler Arm
      control arm bumpers
      ordered!
      Sways now ordered too!
