Results 21 to 32 of 32
Thread: Some new pics
02-09-2005 #21
- Aug 2004
- 132
I reaallly like the valve covers ....where did you get them and how much where they?That is if you don't mind tellin
02-09-2005 #22The valve covers are from Pro-Form. I think they retail around $314.00 for the pair. You may have to hunt for them......I had to special order Mine.
Daniel Kuehn
'71 C-Prepared Chevelle
02-10-2005 #23On your first photo of the inside of the front horn of the frame. Did you double plate the frame there? Or is that a section that you replaced?
I really like the idea of the coilovers on the rear of an A-body. It is a good way to spread the springs w/o cutting into the frame rails. When your get some photos of the upper mounts please post. It is an interesting project.
One question, with your coilovers what is the depth of them from the C/L of the axle front to rear? I don't think you are running a PHB or a Watt's link, but if you were would the coilovers require you to mount it further back than just behind the center pumpkin of the axle?
BTW
Nice work.
R.J.
02-10-2005 #24I thought you could run AFCO C/O upside down? Or do you have to run it that way for coil clearance? How do you like those F1 tires?
RJ,
You can run C/Os ahead of axle tubes. Loss of motion ratio is very minor.The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
02-10-2005 #25would you mind to get over here to Italy to do a tunnel for me as well??
Ciao
André
02-10-2005 #26I'd love too...........are You buying?
Originally Posted by Tigergutt
airrj1: Yes that area of the frame is double plated. While the car was sitting with the front end off with jack stands under the frame in that area, I noticed how much flex the frame had right there. I figured a litle gusseting couldn't hurt. The coilovers are about the same depth back as the stock rear shocks would be. WIth this configureation a PHB or Watts link shouldn't be necasary. The GW lower arms do a fantastic job of locating the rearend.
Salt Racer: You can run those Afco's inverted which is what I'll do in front. In the rear I could'nt get the clearence to get the shocks upright enough with the upside down. The tires are Kuhmo V700 victoracers. They are the absolute coolist tire ever!!! I think the V stands for Velcro!Daniel Kuehn
02-11-2005 #27
- Jul 2004
- Braselton, Ga.
- 1,477
