    Results 1 to 16 of 16
      Nov 2004
      In the black hole,Midwest US
      Distributor won't drop in, any Suggestions?
      I have a 350sbc with an MSD Pro-Billet distributor,crane hyd. flat-tappet cam,and an Air-Gap intake. My block has not been decked and I am running a dynagear oil pump. My problem is that when I stab my distributor it drops in until it hits the oil pump shaft and it will not drop in. I know what you are thinking, but my slot is lined up from the dist. and oil pump and if I pull my gear off my dist. it fits into the cam gear and on the oil pump. With the gear off of the dist. shaft the shaft fits right into the oil pump gear. Everything should be dropping right in but it will not, the only way I can get the dist. to drop all the way in is if I drop it in and pull the rotor off and smack it with a hammer. I don't like this and I know it is not right so I am trying to fix it. I thought I had the wrong cam button and timing cover which would be pushing the cam back farther in the block causing the mis-alignment but I bought a Comp. two-piece timing cover with a cam button they sent with it and I still have the same problem. My endplay is .010 which is within spec and all the parts were new at the same time when I built the motor back in Sept. I am at a loss and cannot figure this one out Maybe tommorrow I will spray all my parts with layout dye and drop the dist. in and see exactly where it is hitting. Has anybody ever had this problem?
      1968 Chevy II Nova
      no go, no show
