Results 1 to 9 of 9
Thread: My car used to start...
01-09-2008 #1
New to Pro-Touring
- Jan 2005
- 64
Well it sometimes starts, but rarely. I thought I had solved the problem when I sent my MSD 6al in to get the caps replaced but when I but the box back in my car, it still either doesn't run or starts and then dies. I hooked up a timing light and got the car to start but then the light stopped flashing and then, of course the car stopped running.
I thought it was a bad cap in the ignition box because I had eliminated the power/grounds but continued to have an inconsistent problem where the car would start and randomly it would die but then run fine for days. All this seemed consistent with a problem in the ignition box.
I know I have inconsistent spark but I’m out of ideas. I have checked the ground, power, traced all wire to/from the ignition box, sent the box into MSD for repair, checked the dist. (looks to have been firing)...
Ideas...
Dave Denysenko
67 Camaro
01-10-2008 #2
- Nov 2007
- 266
what type of coil are you running? I had this issue with an MSD blaster coil that was mounted horizontally. These are oil filled and after a couple minutes if the oil isnt bathing the windings it will over heat and stop firing. If you look at the instructions it tells you not to mount it like that but it is in very small letters. IF in fact you have an oil filled coil that is mounted like that, get a new one and either mount it upright or get an epoxy filled one like the black blaster coil and yoy can mount it front ways, side ways back ways. This is just one possibilty maybe itll help.
01-14-2008 #3
New to Pro-Touring
- Jan 2005
- 64
Thanks for the help but unfortunately I'm using an HEI dist. with the coil in the cap.
I have to be missing something?!Dave Denysenko
67 Camaro
01-14-2008 #4Maybe dis-connect MSD box from system to rule it out. If it runs fine without it will have at least narrowed your problem down to wiring or the box itself. Worth a try IMO
-MArkMark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
01-14-2008 #5
