Results 1,241 to 1,260 of 2412
Thread: $5000 budget Mustang
08-24-2010 #1241
- Dec 2004
- 333
>now carbon fiber, to do it the right way, not so much.
CAn you expound ? I have heard that
1) CF is more delicate when handling and cutting
2) it tends to curl up at the edges while curing, especially in mold less construction.
Why else would it be more difficult to work with ? You don't have to vacuum bag it except to cure problem #2. I'd be interested in your experiences.
08-24-2010 #1242ok, well, I must admit I've never used CF. but I did stay at a Holiday Inn Express last night.
here's what I've gathered:
- the dry fabric itself is very hard to deal with. you need to tape everywhere you cut so the fabric doesn't fray
- FG can use poly resin versus CF must use epoxy resin. epoxy is actually better, but harder to deal with
- IMO, to do CF right is to vacuum bag it. otherwise you've just got a fiberglass part that has a pretty black pattern. that means extra equipment and more work
- it's a lot more expensive, which makes screw-ups expensive
08-24-2010 #1243Well, if you want to make something out of carbon fiber and you're going to paint it, I'd imagine aligning the weave isn't as critical. Many CF hoods and other parts are fiberglass reinforced, so essentially they use the CF as decoration. To make a CF part truly light weight requires more than just brushing on resin and adding layers like we'd do with fiberglass... It can be done, but a lot of the weight would be because of excess resin.
Aren't production CF parts made of that impregnated cloth that has the resin in it or something, reducing the amount of resin needed?'69 Chevelle - LQ4/T56
'71 GMC SWB Fleetside - LM7/AR5
08-24-2010 #1244
- Dec 2004
- 333
Yes, high quality CF is made with pre-preg which has the resin already impregnated in it with the correct amount. However to cure it requires an autoclave which is an oven that also creates atmospheric pressure, so it is out of reach for most peopl especially on automotive scale parts. Even a small autoclave is probably a bit spendy. I believe parts going in the autoclave still require some bagging or absoprtion ply too, so its not as easy as just laying it down.
08-24-2010 #1245
