Results 1 to 12 of 12
01-07-2008 #1
- Oct 2007
- ridgefield ct
- 876
what's the best style differential?
for primarily street driving what's the best one that will work in a buick 8.5in rear? right now i'm planning on a eaton detroit truetrac.
01-08-2008 #2What kind of power are you putting to it? Plan on power mods?
Truetraks are great.Mark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
01-08-2008 #3
- Oct 2007
- ridgefield ct
- 876
i figure my engine puts out a max of 400hp and 450tq.
i'm keeping the 200-r4 but am getting a 2500 stall converter.
the rear suspension will get stronger parts but i'm sticking with the GM designed 4-link. i'm sure that i won't be able to resist doing the occasional burnout on the street, but it's not a drag car(maybe once a year). i have 275/40/18 'vette tires/wheels in back.
01-08-2008 #4oops
Mark
LS1- T56
under construction
01-08-2008 #5I'm no drivetrain expert here by any means, but here's my .02 cents.
Sounds like you are making decent power, and I know Buicks can make some big torque #s down low. If you plan to street drive and occasionaly drag race you shoud be ok with the 8.5 and truetrack, maybe some beefier axles wouldn't be a bad idea. Remember, doing burnouts does not put your axles to the test, but if the car really "hooks up" repeatedly, your gonna' find out where the weak link is pretty quickly.
With that said, get the best and biggest you can afford, keeping in mind future upgrades to power output so you don't end up spending more later. I always try to over-build as far as my wallet will let me.
I ran a stock 8.5 and axles in my Trans-Am for years behind a pretty hot 455, and I drove the wheels off it. Never any rear end problems.
If you are running a full size Buford, (Heavy car) than you might consider stepping up to a 12 bolt or a Ford 9" if you are going to really romp it MarkMark
LS1- T56
under construction
01-08-2008 #6
- Oct 2007
- ridgefield ct
- 876
it's a 87 monte, i just want to get rid of the notoriously weak 7.625 rear for something reliable. i will be getting rid of the c-clips, and getting it professionally rebuilt with new gears and 30 spline axles (at least that's the plan). i really don't want the diff to be the weak point.
actually i'm starting to wonder about the truetrac. eaton's website says that it will spin one tire then transfer the power and equalize both axles. i wonder if it will hold up to me.
or if should go with a standard clutch disc style. this is my first build, that's why im so clueless. sorry for the aggravation
01-09-2008 #7I may be getting past my own true knowlege here, but I am pretty sure the the clutch types do the same thing, just not as well. If you want to have true "posi", I think you will need to go with a locker.
Originally Posted by megaladon6
I am not a drag racer, so I have never seen the need for a locker in a street driven car. I do have ARB lockers in my Jeep, but these require an on board air comp. to operate. They work relly well for that app. as when they are in the unlocked position they act like a open diff. Very expensive set-up though.Mark
LS1- T56
under construction
01-09-2008 #8
- Oct 2007
- ridgefield ct
- 876
definately don't want a locker. i don't really like driving in a straight line. i just want to be sure that i won't snap the truetrak.
01-09-2008 #9"i don't really like driving in a straight line."
LOL, my driving style tends to be more sideways too!
Just get the best you can afford to buy, the Eaton unit is very strong!
Like I said earlier I ran a STOCK 8.5 w/ limited slip for years without probs. Just gotta put the additive in there when you change gear oil so you don't get clutch chatter.
Maybe someone else can chime in here to clear up differences between the different units. I can see I need to learn more about this myself.
MarkMark
LS1- T56
under construction
01-09-2008 #10
