    Results 1 to 10 of 10
      Jan 2007
      Royal Oak
      Trick to getting GM HEI Distributor into 68 Camaro?
      Is there a trick to getting GM HEI Distributor into 68 Camaro? When I try to install the distributor hits the firewall.
      Thanks for any help.
      Sep 2002
      San Jose, CA
      Yep - that's a problem with all 1st gens, the HEI won't fit a stock firewall.
      Some guys beat the firewall back with a hammer, but I wouldn't.
      Spend the money for an MSD small cap dist and be done with it
      Just call me Brett
      before the car was in paint I clearanced the fire wall.
      Feb 2007
      You could use mounts that move the engine 3/4" forward or just junk the HEI and get an MSD pro billet and coil.
      Check your frame position. With the frame in the correct position there IS room for a large HEI distributor while using a stock cross member. Look in the forward body mount brackets (near the firewall) and you will see a small .610" (a little smaller than 5/8") hole. If you put a dowel or alignment pin in this hole it should align with a corresponding hole in the body and the pin should point straight up and down. Sometimes the frames are removed from these cars and not put back in the stock position or they get bumped and move over time. I had an HEI in my freshly restored 69 Z/28 RS. It was a close fit but it did fit.
      USA
      B.f.h. ! ( LOL)
      Jeff Tate
      U.S.A.
      Fontana, CA
      Quote Originally Posted by JEFFTATE
      B.f.h. ! ( LOL)
      I did that 8 years ago!! Still have the scars on the firewall too. I also broke the seam to the upper cowl doing it!
      Nick R.
      USA
      Yeah , me too.
      Actually my car already had it done when I bought it.
      Fastrc5 , just "massage" the firewall until you get enough clearance.
      Or if you don't want to rig it , buy an MSD.
      Jeff Tate
      U.S.A.
      I bought an MSD Billet after cracking my HEI cap on my old 68.
      My issue is the trans cross member is the wrong one and tilts the motor down in the back.(hack mechanic) Check all you mounts and body bushings for wear and such.
      Feb 2007
      Information for any other first-gen Pontiac guys- HEI does fit and not have any problem with the firewall with a Pontiac engine. HEI however, does not work with the tri-power manifold. I learned that one on my GTO.
      1969 Firebird convertible M4 (project)
      Manual steering, drum brakes, top and windows.
      Pontiac 350 7.6:1 compression ratio w/ 2.56s out back! 0-60 in under 5 minutes
      Metallic brown w/ an eagle airbrushed on the hood! Worse yet the original color was red...
