Results 1 to 8 of 8
Thread: Pulley issue need help please
01-04-2008 #1
Hey all,
Dang belt (serpentine) keeps rolling off the back of the back of the power steering pulley at high rpm. Not all the way off, but about 1/8" and just rides there chewing up my new belt.
All accessory pulleys are from S&P (a/c, idlers, and p/steering)
I have issues with several S&P products I have puchased, but that's another story.
I had the old p/st pulley removed from pump and the S&P one pressed on at local Napa, and when I picked it up, I could see right away that it was not pressed far enough on. Mach. shop guy said that was as far as it would go on, and he scratched it up a bit in the process. Paid him his fifteen bucks to get my pump out of jail and took it home to try it. No dice, it was way off. Took it back and guy said nothing he could/would do for me and no refund, wouldn't even pull it back off for me! Have not been there since! Bad man! Grrrrrrrr
Took it to another shop. (Carquest) Guy said he would try, and was able to get it pressed on quite a bit farther, didn't even charge me for the work. Good guy!
Took it home to try and.................
That's where I am now, all the other pulleys seem to be ok, so I'm sure this p/st pulley is still not pressed on far enough.
Bad pic, but back of pulley is aprox. 1/4" from res. tank.
does this look right? If so, my prob is elsewhere.
Any LSX guys or gals out there with F-car accessories that would be willing to take a measurement of pulley to tank clearance and post what yours is?
Mine is 1999 LS1 f-car if that makes a diff.
Thanks in advance, MarkMark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
01-04-2008 #2
- Mar 2005
- Jackson Ms
- 1,220
call S&P
Chris V
SOLD
01-04-2008 #3
- Oct 2007
- ridgefield ct
- 876
could the pulley be backwards?are there any spacers behind it? are all the other pulleys aligned?
work in progress--for the next 10 years.
1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
01-04-2008 #4
- Aug 2004
- Dunwoody, GA
- 4,984
