Results 1 to 2 of 2
Thread: Another welding question
12-19-2007 #1
- Feb 2005
- 320
I would like to weld a 1/4" piece of steel to a 1/8" piece of steel in a T fashion. Now if I was just going to weld the 1/4" to the 1/8" without beveling the 1/4" first I know I would use the settings on the welder for 1/4". BUT IF I do bevel the edges of the 1/4" plate to roughly 1/8" would I then use the 1/8" settings on the welder????? BTW mig welding. Thanks Chris
12-19-2007 #2
Either way you'd set it for the thicker peice, then try to keep the weld and heat more towards the thicker piece. You can either weave a little while welding or practice first to get your ratio (80-20 or 60-40 for example) down pat. The weld will be hot enough to burn through the thinner peice if you keep it on there for too long.
