Results 1 to 11 of 11
Thread: Primer after blastin
12-18-2007 #1
- May 2007
- Midwest City, Ok
- 306
I'm picking up my car tomorrow after getting blasted. The guy that is going to prime had me pickup the primer and activator tonight. The primer is 2k acrylic urethane, would this be ok on bare metal and hold up for a year or two until I get the paint and bodywork done? Thanks for the help.
Dustin
12-18-2007 #2
- Sep 2007
- Elizabeth City NC
- 233
nope You need a epoxy primer to go over bare metal or you can metal etch first then use your urethane but the epoxy is best
67 camaro
12-18-2007 #3
Starting The Transformation
- Nov 2007
- Moore, Ok
- 103
I used etching primer.
12-18-2007 #4I also used epoxy primer.
12-18-2007 #5
- Feb 2007
- USA, TN
- 850
I'd use the epoxy primer. Etching primer has limitations as to what goes on top and I don't think it seals out moisture.
12-18-2007 #6
- Sep 2007
- Elizabeth City NC
- 233
You are right etch primer will not seal out moisture but the urethane will. seems much easier to just put a coat of the epoxy on than to etch prime then put the urethane on.
Originally Posted by TnBlkC230WZ
67 camaro
12-18-2007 #7
- Dec 2007
- norman ok
- 387
