      Nov 2007
      Rear Tire Size 64 Malibu
      Hey Ive searched on here and on team chevelle and Im still lacking on a tire size I can run. I came across a few early A bodies but they were running a stock or slightly lower rear suspension and I want to run way lower ~8 in to the rocker. Id like to run a 17 inch rim and I think a 285 40 17 should work but Id like to know if any of you guys have run a wider tire with a pretty low stance. BTW I have no intentions of minitubbing/narrowing the frame rails as tempting as it is, I dont have the time to do it. So please help I wanna buy some rollers and this is a sticky point.
      Jul 2002
      Mesquite, TX
      I couldn't fit a 275 in my 65, but all of them old cars are different, you may have a little more room in there than I did.
      My previous 65 fit a 255 without issue.
      Southern NJ
      275 is max without a minitub, and even that will likely require some fenderlip and inner fender massaging. I'd do a lot of measuring, there are a lot of early A-bodies with the rear end slightly off center. I've had rear wheel/tire combos that fit better on one side than the other, which can be frustrating.
      Since you're going to be so low, you might want to consider a 255. The fenderwells get pretty narrow up top.
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      Alta Loma,SoCal
      I "think" I can get a 275 to fit if used on a 9" wheel, maybe a 10" on my 65. I have a 275 mounted on a 17x9 steel wheel now, and it fits under the car, even with the 4.5"BS on the wheel. There is still a bunch of room on the inside to move it in with the right BS. My car is dropped 2.5" in the rear.
      1965 Buick Skylark
      Nov 2007
      unfortunately for me the supension is all fu@%ed up and I cant really get a reading as far as stock height is concerned. Thats why Im just measuring from the rocker panel in front of the rear wheel well. I have a 65 mustang in the shop that sits perfectly and its 8 inches at its rocker except for him hes running a 225 with next to nothing for backspace. So he looks like he has a wide tire until you look at the back and see that its a real pie cutter of a rear tire. I may just mini tub the car although Im scared to do it figuring that itll take forever but I may not have a choice considering I want to make 550-600 rwhp and ill need somewhat of a contact patch.
