    Thread: -58 chevy
      Oct 2006
      Norway
      -58 chevy
      Hi!
      Are there any stock GM disk brake spindles that we can adapt to my friends -58....With aftermarket arms or a kit. He has several GM pat cars from the 80's
      Olav
      Oregon
      Anything can be adapted with enough fabrication and steering correction. One guy I'm aware of, Boris at Street Machinery in Euclid, OH has adapted the later modular GM short-spindle from the '68+ A/F/X-bodies to them, however he now typically just runs C5/C6 stuff with KORE3 kits designed for the 58-64 B-bodies.
      If I'm not mistaken, you could probably use C3 brakes as the spindles are very similar between the two. By the time you make the necessary modifications and buy the 4-piston Delco Moraine calipers though, you probably could have gone C5 for less. Nothing from the 80's comes to mind as being anywhere near compatible, unless you're looking at drop spindles where they use the late-model G-body brakes...talk about barely being an upgrade.
      It's what I does.
      Oct 2006
      Norway
      Okey.....Thanks!
      Olav
      When you get a chance please start a project update. I've loved 58s since I first saw American Graffiti.
      Jun 2006
      Katy,TX
      I thought I saw Scarebird had a bracket for 58-64 Chevies to use a GM rotor and caliper.
      Try these two places, maybe they can help??
      http://www.tsmmfg.com/
      and
      http://www.ecihotrodbrakes.com/
      As well as ask David Levesque, Steel Tech Solutions Inc., PO Box 1101, Marion IL 62959 if he can help.
      And also what does Master Power sell for the '58 now??
      pdq67
      Oct 2006
      Norway
      Thanks!
      Seems like our cheapest/ easiest option is to use early Camaro/ Nova brakes with a kit from one of these suppliers.
      Olav
