Results 1 to 20 of 23
12-02-2007 #1
Front Suspension Rebuild Help 73 TA
I'm planning to rebuild my front suspension and have the following questions for you 2nd gen suspension guru's. Let me know what you run and what you would have done differently!
Currently stock A arms with poly bushings. Planning to go with aftermarket arms on top and new bushing on the lower. Any reccommendations on arms, bushings, tall balljoints?
Need new balljoints, inner & outer tie rod ends ect. Best type & source?
Currently running stock springs, stock sway bar/poly end links with KYB shock. Stick with stock springs as ride height is where I want it? New shocks? New sway bar needed?
Stock brake calipers with stock rotors & pads. Reasonable upgrades for these parts?
Car is street driven with 1/4 mile and autocross track time. Want it to handle well with reasonable budget. I know the sky is the limit!Last edited by 73ta; 12-02-2007 at 12:03 PM. Reason: Astetics
1973 TA G Machine
2000 BMW 540 G Sedan
12-02-2007 #2
I'll ask you the most important question... budget?
Just call me Brett
12-02-2007 #3
$2500 max.
1973 TA G Machine
12-02-2007 #4
The name of the game here is chassis bracing...
I would be looking at the PT Fbody's Stopflex kit
Now as far as the balljoints tie rods and such, just use Moog
Shocks - Its hard to beat Edelbrock for street driven 2nd gens
A-arms - well there are a lot of choices depending on how much you want to spend and how much install time you want to spend.
Front runners
Global West
Detroit Speed
SC&C
Pro Touring F-Body1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
12-02-2007 #5
Lots of info on A-arms here
http://www.nastyz28.com/forum/showthread.php?t=1050251971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
12-02-2007 #6
