    Results 1 to 20 of 23
      Lodi, Ca
      Front Suspension Rebuild Help 73 TA
      I'm planning to rebuild my front suspension and have the following questions for you 2nd gen suspension guru's. Let me know what you run and what you would have done differently!
      Currently stock A arms with poly bushings. Planning to go with aftermarket arms on top and new bushing on the lower. Any reccommendations on arms, bushings, tall balljoints?
      Need new balljoints, inner & outer tie rod ends ect. Best type & source?
      Currently running stock springs, stock sway bar/poly end links with KYB shock. Stick with stock springs as ride height is where I want it? New shocks? New sway bar needed?
      Stock brake calipers with stock rotors & pads. Reasonable upgrades for these parts?
      Car is street driven with 1/4 mile and autocross track time. Want it to handle well with reasonable budget. I know the sky is the limit!
      1973 TA G Machine
      2000 BMW 540 G Sedan
      Sep 2002
      San Jose, CA
      I'll ask you the most important question... budget?
      Just call me Brett
      Lodi, Ca
      $2500 max.
      1973 TA G Machine
      Sep 2002
      San Jose, CA
      The name of the game here is chassis bracing...
      I would be looking at the PT Fbody's Stopflex kit
      Now as far as the balljoints tie rods and such, just use Moog
      Shocks - Its hard to beat Edelbrock for street driven 2nd gens
      A-arms - well there are a lot of choices depending on how much you want to spend and how much install time you want to spend.
      Front runners
      Global West
      Detroit Speed
      SC&C
      Pro Touring F-Body
      Just call me Brett
      Sep 2002
      San Jose, CA
      Just call me Brett
      Florida
      in "The 14 Car" I run
      Stock UCA's and LCA's (tubulars weren't out yet)
      Global West DEL-A-LUM control arm bushings
      Hotchkis offset upper control arm shafts
      Hotchkis springs (they lowered the car about 3 3/4 inches from stock)
      Hotchkis sway bar
      Bilstien shocks (from Hotchkis)
      Energy Suspension poly body mount bushings
      Stock spindles
      Spicer ball joints
      Moog centerlink and tie rods
      Hotchkis tie rod adjusters
      Amsoil synthetic grease
      bolt in SFC's
      Stock discs W/ Raybestos Heavy Duty Semi Metallic pads
      Forget whose bearings I used
      New stock master cyl
      new steel brake lines and flex lines
      Hurst Roll Control line lock
      TT II's 17 x 9.5 W/ Yokohama AO32's 275 40 17 for road course
      Centerline 15 x 3.5's with Mickey Thompson skinnys for drags
      Things I'd do differently
      Tubular control arms(because they're available now)
      My car spends a lot more time on tracks now and I trailer it to most events that are over 300 miles away. I used to drive the car from CT to Florida on vacations at the time I did the suspension work and before I had a trailer. So these things I'd change since ride quality isn't as important to me now.
      Gen II solid body mounts
      Gen II G brace (will probably install this year)
      Weld in sub frame connectors (will probably replace the bolt ins)
      Lodi, Ca
      Thanks for the replys. I think I have a good idea now.
      Not A TA: do you have ay pics of the ride height? How much suspension travel left? I'm running the same wheels, measurement from fender lip to ground?
      1973 TA G Machine
      Florida
      If I remember correctly I did change the bumpstops per Hotchkis's recommendation. I never measured the travel but I haven't felt it bottom. I figured the engineers at Hotchkis know more than I do so I just installed the parts they recommended as far as springs , sways, shocks, control arm shaft and the bumpstops.
      I did get a slight tire rub on the upper inner fender when hitting really hard bumps when I ran Pontiac Rally II's 15x7 with 255 60 15's. When I got the TT II's I had the custom backspacing done at 5.5" for the fronts. I don't believe that the off the shelf TT II's have that much backspace. I can't remember the fender to ground measurement so I'll measure the next time I take it out.
      This pic from Lime Rock is from a few years back but shows the ground clearance
      Aug 2005
      First, NOT A TA, that is a really, really, good looking car!
      Second, I'm going to go through the front end of my 73 Camaro his winter, was going to use this
      Kit for the joints and a poly bushing kit for the control arms.
      I have no problem drilling some holes and making them greaseable if squeaking becomes annoying.
      I already have 3 way shocks, and the stock 'Z28' sway bar to go in. Can loosen the bar off at the strip and tighten down for the drive to and from. So the suspension does pretty much what I want it to do.
      If my alignment is OK I'll stay with the stock arms. Unless someone can post up some decent $/lb numbers I'll keep my stock arms
      I will use 1/2" thick poly, upper a arm bumpstops again.
      'Stock front, springs, '73, 350, w/air, RS car', and they seem to work fine with my no air, aluminum head, intake, w/p, rad, pushed back 1", BBC.
      IL/TN
      ZS10 take a look at our Comp upper arms 1/2 the weight for $259 a set with built in castor and solid greasable bushings on billet offset cross shafts almost not worth dealing with stock ones
      Lodi, Ca
      Not A TA:
      Sweet car. Thats the look I'm looking for. Here's my current ride height stock springs frnt & bk. Looking for a little higher in the rear stock springs from 1973, very old. Front springs are for AC car and are newer stock springs about 8 years old.
      1973 TA G Machine
      Jan 2007
      NOT A TA and 73ta... wow, those are gorgeous cars!!!!!!!!!!!!
      73ta... what size wheel tire combo is that? And what backspacking did you use?
      1994 Corvette
      Florida
      Thanks for the compliments guys!
      73 TA
      Thats a great looking car! I had a white 75 TA 400 auto with that sticker package on it I sold a couple years ago.
      I'll be bringing mine over to my shop next week to get started on the winter projects and will measure the heights.
      The Gen II upper arms mentioned above by 79T/Aman sound like they might fit into your plans.
      1. Pressing Global west bushings into stock arms requires fabbing a spacer/support to keep the arms from bending/twisting, a large press, and care to make sure the grease fittings end up in an easy to reach position with a grease gun.
      2. The solid greasable bushings are included in the price.
      3. The offset shafts are included in the price.
      4. Less flex / lower weight
      What discs are you running on the rear?
      Jan 2007
      Quote Originally Posted by NOT A TA
      Really? I'd never heard this before. I've got a set of Del-A-lums UCA bushings and GW's offset billet crosshafts that I was going to use with my stock UCAs... exactly what kind of spacer/support is needed?
      1994 Corvette
      Florida
      I'll have to look at them since it's been a few years since I did them and I may be thinking of the LCA's. I remember that the sheetmatal was starting to flex as I increased pressure with the press to install the bushings. Knowing that sheetmetal will crack easier after being bent back and forth I stopped and made a support.
      IL/TN
      GW used to includ a small metal plate to be welded across the lower control arm bushing "ears" to keep them from bending but they also changed the bushings in the past 8-10 years to try to help with that problem ( smaller OD. so they go in easyer)
      Jan 2007
      I was just reviewing Tony Huntimer's "How to Build & Modify GM Pro-Touring Street Machines" and found where it said that welding in a plate to reinforce (and prevent flex) in LCAs was a good idea, but it didn't say anything about the UCAs needing such reinforcement. Since I'm going to just run stock rubber bushing in my LCAs I should be okay, right?
      1994 Corvette
      IL/TN
      yes you'll be fine with the stock bushings in the lowers Jon
      Jan 2007
      And the UCAs with the GW Del-A-Lums are okay without reinforcement?
      1994 Corvette
      Lodi, Ca
      O'neal wheels are front & back 17 X 9.5 with 5.5 BS if my memory is correct. tires 285/40 rr & 265/40 frnt.
      Not A TA rear disc setup came off of a 79 WS6 TA.
      79 TA man I'm saving my money for some of your goodies!
      1973 TA G Machine
