      Oct 2007
      Drop Spindle Problems 88-98 Chev
      Has anyone ever had any problems with belltech drop spindles on Chev Pickups? Mine are built in two pieces, the knuckle, which looks like a forging,and the spindle pin, which is machined and looks press fit. To the problem at hand, while changing the oil on my truck, i noticed extreme wear on the inside of my driver side tire, and upon further inspection noticed that my press fit portion of the spindle looked to be at a different angle than my right side which is wearing perfectly fine. Anyone had this problem? This is just one of the many woes I've had with my drop kit since i recieved it.
      Rowlett Tx.
      I've done several trucks using Bell-Tech spindles w/o any problems. Of those trucks, 3 were 88 ~ 98's & used their 'kit' (spindles, springs, flip-kit, c-notches).
      It's always possible however that there was a QC issue w/a manufactured part. If in doubt, diassemble things so you can accuarately measure angles to confirm or dismiss your suspicions.
      Huntington Beach, CA
      Did their kit on my 92 about 10 years ago. Tire wear has been horrible ever since. Despite alignments the outside edge of both tires wear really really bad.
      Oct 2007
      Yeah. I just haven't had much luck with this kit. The first go around I got the wrong shocks, so it was like I had check straps instead of absorbers. Now this too, I've got major toe issues and I think it messed up my caster as well cause the steering has went all vague feeling with no return and some wicked bumpsteer to boot. Too bad I already melted down the stockers...
      Rowlett Tx.
      I have some Bell Tech spindles on my 74swb pick-up that's been my daily driver since '04.
      I lowered the truck in '03. It saw limited milage (mostly shows or weekend stuff) & I had to replace the 245/45-18 Dunlops after 1yr. because of wear on the tires edge.
      I took the truck back to the same guy just to dbl. check the alignment specs. The only issue I had after the original alignment was the steering wheel wasn't perfectly centered. We all know how annoying that is to gear-heads; other than that the truck drove straight. After about 9-months, it developed a pull to the right that grew increasingly worse as the tires developed wear patterns.
      The alignment was still in spec other than the changes to the toe setting/s to correct for the off-centered steering wheel. The truck has been on the road since (daily use now) & is still using that second set of Dunlops.
      My 'kit':
      B.Tech 3" spindles + 1-coil removed from the stock V8 springs
      Western Chassis rear leaf flip-kit & lower shock bracket extensions
      B.Tech dropped shackles
      I say get the alignment verified.
      Burleson Tx
      I have had a set on my suburban for about 4 years with no problems. I also cut a coil out of the spring with no tire wear issues. Sounds like you got a bad one. Alignment tech seems like should have caught that. Not easily overlooked when doing an alignment. i have used their spindles on many a project with no issues. I have done many an alignment and have found bent spindles while performing the alignment.
