Thread: Drop Spindle Problems 88-98 Chev
- Oct 2007
- 9
Has anyone ever had any problems with belltech drop spindles on Chev Pickups? Mine are built in two pieces, the knuckle, which looks like a forging,and the spindle pin, which is machined and looks press fit. To the problem at hand, while changing the oil on my truck, i noticed extreme wear on the inside of my driver side tire, and upon further inspection noticed that my press fit portion of the spindle looked to be at a different angle than my right side which is wearing perfectly fine. Anyone had this problem? This is just one of the many woes I've had with my drop kit since i recieved it.
11-28-2007 #2
- Aug 2004
- Rowlett Tx.
- 201
I've done several trucks using Bell-Tech spindles w/o any problems. Of those trucks, 3 were 88 ~ 98's & used their 'kit' (spindles, springs, flip-kit, c-notches).
It's always possible however that there was a QC issue w/a manufactured part. If in doubt, diassemble things so you can accuarately measure angles to confirm or dismiss your suspicions.
11-29-2007 #3
- Apr 2006
- Huntington Beach, CA
- 2,420
