Results 1 to 20 of 23
Thread: What ignition to use???
08-18-2004 #1
I am wanting to upgrade the factory TFI in the towncar and wonder what I should use. I was thinking the MSD 6AL. But don't really like the pill type of RPM adjustment. I may go with the digital 6 or Accel or ???
Any sugestions for a Ford EFI 5.0
Tim89 Lincoln Towncar pro touring project ( new info found for handling)
95 Explorer XLT OFF-Roader
95 Chevy Suburban LT 4X4
07 Harley XL1200L Low 08 Harley XL1200N nightster
Would you vote for someone who doesn't stand up for the flag?
08-19-2004 #2
- Aug 2004
- 3
Ignition
You should try one of the mustangs sites, I'm sure that they will have numerous ignition systems for you to look at. Assuming the engines are similar. I'm pretty sure they are. Try that out, you should have a better response.
08-21-2004 #3
Most mustang forums treat you like dirt because it isn't a me too car( gotta mustang me too) I figure I would get more info here but I guessed wrong.
08-21-2004 #4dennis68 Guest
Hey. Mr. Arrogant here. I would go with MSD-6AL. Great box, never had a problem with any of my MSD stuff and customer service is pretty dang good.Try over at corner-carvers.com. Make sure to tell them you are new to the site and you have a Town car looking for advise. They will help.
08-21-2004 #5
Originally Posted by dennis68
Oh sure Dennis, feed the big meany-heads! Tim, I would also agree that it is hard to wrong with MSD. Don't know enough about the thin film stuff to be much more help tho.Brian D
Snotty Bimmer driver.
08-21-2004 #6
try an MSD digital box instead
You might want to look into a digital box like the Digital 7. It has far more spark energy and when you eliminate an analog sytle ignition control and go digital, you get better throttle response and way more power. -G
08-21-2004 #7dennis68 Guest
Way more power over an analog box, I wonder what kind of research was done to come to this conclusion. It is pretty well documented that going from a good, tuned, electronic ignition system to a "better" electronic ignition system is rarely worth more than a few horsepower at any RPM range. There a number of pro's to the digital system but "way more power" is not one of them.
This sounds like an add for Bosch platinum +4 spark plugs at 15/ea or whatever the newest precious metal spark plug is. It either ignites the fuel mixture or it doesn't.
08-22-2004 #8
In the past on my many 5.0 build ups I upgraded the coil, wires and plugs and kept the rest of the system stock. Ford makes good ignition sytems. I'd use the money else where. Or if you really want to go aftermarket I'd go with the MSD crowd. I have used many MSD6-AL without any problems. I haven't gotten the opportunity to play with the new digital boxes yet. Been thinking of one for the 4.6. A lot of newer engines of course are going to coil on wire system (i.e. LS1) so this stuff doesn't work for them.
Brian
'68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
08-23-2004 #9
oh, not much power?
Well Dennis, let me explain it this way. MSD 6A compared to MSD Digital 7 Plus. 190 millijoules per spark compared to 105? Or, there is 535V of primary voltage compared to 460-480. Then there is the EMI filter, retard feature up to 9.9 degrees, two rev limit controls, a 15 Megahertz micro processor....I think the differences are day/night in terms of power. -G
08-23-2004 #10dennis68 Guest
Those are all customer conviences that we have had to find other methods of accomplishing for decades. They do not in any way add power to overall horsepower peak output. If that were the case all I'd have to do is buy a 250.00 ignition box and add 25 HP correct? Boy that sounds like a Flowmaster cat-back ad, or a K&N filter one for that matter. It's true a nice digital box could add 20-30 HP over base, as long as base is old worn-out stock parts like most companies use when they boast of HP increases.
08-23-2004 #11
Dennis, I'm comparing MSD 6AL to MSD Digital 7-not "stock, worn out parts..." Basically, any ignition system's job is to burn as much of the air/fuel mixture as possible, and the Digital boxes allow you to use MUCH more spark energy for just that purpose as well as incorporating features that some peopel may have not thought about or know how to deal with otherwise. More spark energy equates to more power-that's it. Anyway, it was only a suggestion. I think people should at least think about the benefits of using an updated box much like people here are upgrading their brakes, suspension, etc. -G
08-23-2004 #12dennis68 Guest
I know what you are trying to say. You are trying to say simply upgrading from a 6AL to a digital 7 series will automatically increase horsepower and that simply is not true. If you upgraded from crappy stock worn out stuff to a digital 7 then you would see significant horsepower increase. Just replacing a really good cd box with a more advanced cd box will not show a significant enough gain to justify the cost. 1-2 horsepower, if that, is not in my opinion enough of a gain to spend an additional several hundred dollars. I guess if it really is that much of a pain to have change the pill for the rev limit then you should buy the dial digital system. Not trying to start a feud, you'll find that I have a bad habit of calling folks out who do not back up their claims with tech (too much c-c.com I guess).
08-24-2004 #13
