    Thread: Body Gaps
      Jun 2002
      Santa Clarita Cal,
      Body Gaps
      Hi all,
      what is the recomended body gap in this area, i thought it actually was 000 to .060, body man claims 1/4",is he correct?
      RSK68
      Rick Klein
      Houston, Tx
      1/4 seems pretty thick. I think that closer to 3/16 is more like it
      Sep 2007
      Elizabeth City NC
      3/16 sounds better to me to 1/4 is to much IMO.
      67 camaro
      Miamisburg, Oh
      3/16" is what I keep seeing as the reference when I'm reading around.....
      Mar 2004
      Mid-Michigan
      It will depend on the car... Build tolerance is the determining factor. Being that the rockers are not adjustable and the fenders float around on the subframe, there is no hard number you can use to set up this gap. All you can do is get it as tight as you can while aligning the rest of the clip. Leaving the subframe "loose" at the initial alignment can help as you can pull it rearward a bit to close up the gap (if everything else allows that adjustment). Pay close attention to the door gaps and use those as your guide. If you still don't like the lower fender gap you can always add a bit of steel to the forward edge to close it up...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Aug 2006
      Houston, TX
      I believe the gap between the rocker and front fender (portion you you have circled) should be as close to zero as you can get it ... there shouldn't be a noticable gap here, and definitely not 1/4"! As stated above, door to fender gap is ~3/16".
      Quote Originally Posted by rsk68
      Hi all,
      Mountain Springs, Texas
      This question comes up on Team Camaro all the time, usually with the same disagreement about what is right. Here's one thread:
      http://www.camaros.net/forums/showth...ker+fender+gap
      Don
