Results 1 to 18 of 18
11-23-2007 #1
- Feb 2007
- USA, TN
- 850
Simply brilliant or really stupid
I'm considering haveing the insides of my doors, front fenders and possibly underside of my hood powdercoated chassis black. I've also thought about powdercoating the outsside of them as a base primer. Is any of this a good idea? Will I have problems painting and bondoing later? My sheet metal is pretty straight.
11-24-2007 #2I dont see why you would need to worry about bonod if your powdercoating the insides of things.
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
11-24-2007 #3
- Sep 2007
- Elizabeth City NC
- 233
Powdercoating the inside of them sounds harmless but I wouldnt do the outside.
67 camaro
11-24-2007 #4
- Feb 2007
- USA, TN
- 850
Will the heat from the powder coating process melt or damage any filler already on the door. or fender?
Originally Posted by Project69
Can you EDP while powerder coating. That would give the outside the same coating as a new panel.
Originally Posted by danbob67
11-24-2007 #5
- Apr 2006
- Bellevue, MI
- 53
I would worry about the heat but I don't have any first hand experience doing this. I know my powdercoater won't coat anything that has filler or paint on it. Seems kinda expensive and pointless to do so. Those are all areas that arent subject to a lot of road debris. A good black epoxy primer and chassis black would be cheaper and hold up great in those spots.
11-24-2007 #6
- Feb 2007
- USA, TN
- 850
My problem is I don't know of a good epoxy primer I can spray in my garage. Most of them are pretty hazardous and require special ventilation equipement.
Originally Posted by Duesey2
11-24-2007 #7
- Sep 2007
- Elizabeth City NC
- 233
Originally Posted by TnBlkC230WZ
EDP is a electro disposition primer it is a little different process than powdercoating and also with powdercoating the surface really needs to be clean that is why parts are usually blasted first so getting the inside of a door that clean would be a little bit tough. Im not really quite sure what the benefit would be to powder coat instead of epoxy/painting these areas.67 camaro
11-24-2007 #8
- Apr 2006
- Bellevue, MI
- 53
You can get a 3m disposable respirator for 20 dollars and do it outside. Primer doesn't care where it's being sprayed. Unless it's cold outside like it is here. Were talking a few coats and when done outside it disperses quickly. Or check a few local body shops, shops in my area like quick jobs like this and some can give great prices depending on the type of shop. Even paying someone to spray this would be cheaper than powdercoating and no chance of warpage. Good luck.
11-24-2007 #9
- Feb 2007
- USA, TN
- 850
How cold can it be? I've used the disposible repirators. Max spray makes a two part epoxy in a spray can as well.
11-26-2007 #10
- Feb 2006
- 52
some people swear by it
check out HOT ROD's project F bomb (easy to get to from their web page... its under project vehicles)
that body guy did the metal and fab work, then powder coated everything. then he lightly blocked it out (not cutting through) and proceeded to fill and block from there. I have heard of other people doing this as well. body has to be cleared of everything that cant handle 500 deg. F and no bondo etc. must be a bare metal surface.
I have a lot of parts powdered for construction/industrial use and the typical process we use goes like this:
-media blast
-acid dip (aka passivated, removes impurities)
-etching/leveling phosphate powder primer (adds a ton of rust resistance)
-powder
we even do this over 304 (aka 18-8) stainless steel to make it live in extreme salt environments.
11-28-2007 #11
- Feb 2007
- USA, TN
- 850
I do like powder coating. I had several parts done such as my heater box and inner fenders. I can't scratch it with a screw driver.
12-04-2007 #12
- Feb 2007
- USA, TN
- 850
I talked to the guy that does my powdercoating and he said the same thing you did. I have surface rust inside the doors and the one old fender and there process will fix it. It really isn't expensive. Most of my other parts were done for a little more than I could do it myself and the stuff is really tough. The insides of the doors and fenders will be complete when I get them back and it will be virtually impossible for them to rust in the future.
Originally Posted by newby
12-11-2007 #13Newby, the body guy did not do the fab work! I did.
12-11-2007 #14
- Aug 2004
- 830
body work includes hammer and dolly work, this will wreck your powder coat. The very act of using body filler (bondo) includes hammering down high spots. powder coat doesn’t usually flex this much. I don’t see this as a good idea or even close to needed. A high quality surface prep is necessary and then use an epoxy that will actually etch into the metal then top coat to what ever level of finish you want.
12-11-2007 #15
