Results 1 to 10 of 10
Thread: 69 manual brakes question
hey guys wow its been a while.....
im in the Oswego East high school auto club, actually im the president, we have a 1969 camaro that we have been striping down to bare metal and doing all of the work ourselves and hopefully this summer it will go down the track. it was a yellow car with yellow interior. (interior is for sale if interested)
the cam we have in the motor is way to big to run vacuum brakes and we wont have power steering. what should i run to make this work without a booster? we will be running front disc with rear drums. any help would be great thanks
"Too bad Dare to Be Different these days could mean Dare to Be Fast. What ever happened to the Cars that Scared people?" John Pearley Huffman
11-20-2007 #2anyone have ideas?????
we have been looking at a wilwood front brake set-up and its got 4-piston calipers and the largest rotor you can fit in a 15" rim. any ideas on what master cylinder to use......?"Too bad Dare to Be Different these days could mean Dare to Be Fast. What ever happened to the Cars that Scared people?" John Pearley Huffman
11-20-2007 #3
- Jun 2007
- Michigan
- 43
You're gonna need to ask wilwood what master cylinder bore size they reccomend for that setup --- I'm not sure what size rotors or pistons you're talking about using. That said, as a (very general) starting point, a 1" bore master from a '70 corvette with manual brakes is a good starting point. You'll need to move the brake pushrod up to the "upper" hole in the brake pedal, which gives better mechanical advantage and you'll need to dig up or make a manual brake pushrod.
11-21-2007 #4
