11-12-2007 #1
- Nov 2007
- 1
Putting a T56 Behind a Poncho 400/455
Has anyone on this forum attempted this swap or conversion with a modern T56 to a Pontiac 400/455 engine?I know Takid455 is doing his as we speak but im just wondering if there is anyone else out there that has done this and has detailed pics and or video. Looking to put a T56 behind a 400/455 in a second gen trans am in the future.
Matt
11-12-2007 #2
- Nov 2006
- Rochester, NY
- 177
If I remember right there are three basic options here. First, and expensive, is that modular bellhousing by McLeod. Second is use an LS1 style T56 with its original application bellhousing and clutch with one of those $40 Chevy to BOP bellhousing adapters from Jegs meant for automatics. This requires some grinding as the Pontiac starter is on the opposite side. I think it also requires a spacer between the crank and flywheel to make up the thickness of the bellhousing adaptor. The third option is really wild and done by a fellow in Sweden who hangs out here I think. He wanted to do this before anyone else thought of it and could only come up with an LT1 transmission (might have even been before LSX days). He cut a traditional Pontiac bellhousing in half along with the T56 bellhousing and welded the two together. Obviously that one takes a great deal of skill and labor but he made it work. His website is propontiac.com I think.
Personally I would look into option 2. Check out the Performance Years Forum and do a search there. It has been done and it can even be done affordably. Hope this helps.
11-12-2007 #3
