      Apr 2007
      left coast
      Procharger needs idler pulley
      It's me again. Still trying to stuff the P-1SC under the hood of my '66 Corvette. I just finished mocking it up and now find that the drive belt rubs the power steering pulley, and barely clears the upper control arm cross shaft. If I lift the belt up about an inch, all is well. Would this be something that could be fixed with an idler pulley, and if so, where is a good place to get one?
      I'm also wondering, since I need a shorter belt, should I take into account the spring loaded tensioner and idler pulley when I measure, or should I just measure around the crank pulley and supercharger pulley?
      Thanks to all with more knowledge than me!
      Jun 2005
      Look at the Dayco HD Pulleys and Tensioners catalog. Pulley are in back. You can find it on the web with a search - it's in .pdf format.
      These are heavy duty pullies for diesel trucks - dual bearings, either powdered metal or billet, and inexpensive at ~$40 each.
      Yes, you can use an idler to route the belt away from areas where you don't want it.
      Jim
      Half-Assed = Half-Fast
      Apr 2007
      left coast
      DeltaT...thanks for the info. Now wondering how these pulleys attach. Do you just run a bolt through the middle?
      Jun 2005
      Best to buy or make a stepped washer for the outer face of the pulley, and use a retainer bolt into a threaded post or maybe straight through to a locknut. I like using threaded posts that the pulley fits on at least 50% of the pulley depth. Strong setup, and these small blowers really like a lot of belt tension.
      Some pretty clear pix at my site:
      http://home.mindspring.com/~jim_fisk/id1.html
      Jim
