    Results 1 to 11 of 11
      Warning Stock Hub Failure
      I just wanted to warn any one that is running stock hubs on their cars. I had a stock hub crack in only 2 sessions with slicks wile testing at Pocono in prep for the XV Event. They did have 10 or so track days on them with street tires.
      I was planning to change the spindles and hub any ways but this was to close to crashing the car for me.
      I put a set of Speed Tech Performance hubs on for the XV event. They are a nice piece. http://www.speedtech-performance.com...prod/prd52.htm
      I do not want to raise any unneeded red flags. I was pushing the car quite hard, I also melted the 2 front valve stems just about off and went through a set of Hawk HPS pads in 80 min of track time.
      So if you plan to track your cars just think about the hubs and spindles.
      Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Yes, that's good advice.
      My C4 hubs lasted 700 miles and 3 track events. Consider them a wear item, and check them before every event.
      jp
      ​John Parsons
      St George Utah
      Thanks for the plug, those should last you more than 80 mins.
      you got the last set so i guess i will need to get a few more built!!
      let me know how they work under your obviously harsh conditions
      IL/TN
      well from the pic it looks like the crack may have been there because it looks like there is paint in it but may have spread during your track time.
      https://www.protouringf-body.com "doing what they say can't be done"
      Jan 2003
      Arizona
      That's one way to drive the wheels off of your car.
      ________________
      Steve Chryssos
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by streetfytr68
      LOL! Aint that the Truth!!
      David Sloan
      Dallas, Ga.
      JP I thought your problem was bearings that you bought from a source you were unsure of and not the hub itself ? It looks like what 79T/Aman said an old crack that has opened up from heat and the hard use. Glad you caught it before it caused damage or injury. After what has happened to you and to JP I think I'll check my hubs and bearings a little more regularly.
      I got my original hubs on ebay (they came in a new box) at hundreds of dollars less than the dealer wanted, so yeah, one of my theories was that they were a cheap import brand re-boxed to look like GM parts.
      I found out later that the hub nut that sets the bearing pre-load had rotated 1/8" of a turn which allowed the hub to come apart slightly and caused the failure.
      So ... I still don't know if the part was inferior, defective, or if I was just unlucky. Until (or if) I get a better answer I'll check them regularly.
      jp
      ​John Parsons
      Aug 2001
      Connecticut
      Randy- good post and a note for all of us to watch. I'm starting to wonder which way to go on the next car... I was thinking APS spindles , but after reading some posts on some of the corvette forums, the sealed bearing units aren't up to the task either. I think it's time for some purpose built spindles with a larger center pin but still on timken wheel bearings for service-ability.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Newbury Park, CA
      John,
      I do not believe that there is a cheapie knock-off of the Corvette hub. Too low a production number for the Chinese to make money at.
      I believe they are all made by Delphi.
      Quote Originally Posted by CarlC
      True, but: many many (most?) GM cars use similar hubs, starting with Buicks way back in '82. Near as I can tell the only difference between all of the hubs is the manner in which the ABS sensor is attached. Chinese manufacturers are probably making some of those, and it would be an easy thing to sell C4 hubs too ...
      I just checked my old ones: they are stamped "Made in the USA". I dunno ... we'll see how the new ones do.
      jp
      ​John Parsons
